Brake Caliper Question
Old 04-26-04, 08:19 PM
MNeier
MNeier's Avatar
Default Brake Caliper Question
Hello,
I was going to take my brake calipers off of my car, but when i turned the bolt, the nut inside turned with it. I asked a friend and he said that they sell a caliper tool for a couple bucks at a part store. Is that what I need?
Thanks,
Mike
Old 04-26-04, 08:22 PM
/Aerostar\
/Aerostar\'s Avatar
if you are referring to the 2 14mm bolts, then you need to turn them clockwise (because you are facing away from the bolt.) When I changed my brake pads, the bolts came off no problem. If the inner bolts are turning, then just get a 14mm open end wrench and hold the inner bolt.
Old 04-27-04, 02:56 PM
lexsc3
lexsc3's Avatar
i think your caliper pins might be moving with the bolt when you turn it so you get a 17mm wrench and hold the pins while you turn the bolt so you can get it loose....one of my pins did the same thing, you can use a adjustable wrench to hold it too.
r3dl4b3l
RX - 1st Gen (1999-2003)
14
02-25-18 09:03 PM
john689089
GX - 1st Gen (2004-2009)
12
03-23-16 11:36 AM
shikbas
03-29-12 06:44 AM
MsbTTSupra
Suspension and Brakes
11-11-11 05:27 AM
Quick Reply: Brake Caliper Question
