tire size and lowering
Old 04-18-04, 10:31 AM
ias
ias's Avatar
Default tire size and lowering
I just bought some 20's for my 99 gs and was told to use 245/35/20 and was wondering if this is correct, and what you suggest for lowering my ride with these wheels, for the best looks? thanks...
Old 04-18-04, 11:16 AM
gs400998
gs400998's Avatar
Default Re: tire size and lowering
Tirerack.com recommends 245/30/20 with 20x8.5 wheels. You will find many threads that discuss this subject in the tires, wheels and brake froum.
Old 04-18-04, 04:48 PM
Neo
The One
Neo's Avatar
Most 20s here are 245/35s. They will be larger than the stock size so there will be some potential rubbing depending on your wheel offset. If you lower the car, the 245/35s will also give you a little more ground clearance, especially if you have a kit on.
Old 04-18-04, 05:47 PM
ias
ias's Avatar
what do you recommend to lower it with? and how low?
Old 04-18-04, 10:26 PM
Neo
The One
Neo's Avatar
It really depends on your taste. Some likes it slammed and tucked. Somw just want to reduce the fender gap. There is also the issue of ride quality. There is also cost. Are you planning on just shocks and springs or you want to do coilovers? Let us know more about what you want to do with the car and we can give more specifics. There is also a plethora of info on lowering with 20s if you do a quick search.
Old 04-19-04, 02:24 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: tire size and lowering
that's if you wanna stay within spec. but 245/30 is really low profile, i would probably go 245/35. overspec, but safe. most people run this size here on CL anyway
Old 04-19-04, 02:25 AM
rominl
exclusive matchup
rominl's Avatar
i only suggest coilovers, no springs and shocks, that's no freedom. coilovers are winners.
how low it depends. offset, width, and size. they all affect the possibility of rubbing
bmoon_007
GS - 1st Gen (1993-1997)
08-24-04 09:55 AM
tis_LEXUS
19
07-22-04 09:50 PM
dannieboiz
07-10-04 01:35 AM
ted920
11-19-03 01:05 PM
dud
09-10-03 03:38 PM
Quick Reply: tire size and lowering
