Correct psi per tire? (19)
Old 04-14-04, 06:17 AM
mrshabo
mrshabo's Avatar
Default Correct psi per tire? (19)
Is there a correct amount of pressure for 19's with 245's in the front and 275's in the rear? I've read people say 40 psi, 32 psi. This is my daily driver and i haven't checked my air pressure for about 5 months since i have gotten these rims. I want to know how much air i should have in my tires. I've read somewhere that you should have 1/100th of your car's weight + 1 or 2 psi of pressure. So if my car weighs 3400 pounds.. I should have around 35 psi? Sorta confused. Can anyone help me out on this? Thanks
Old 04-14-04, 08:10 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Psi
Technically you should run what is listed on the inside of the door for your vehicle. Many people run higher then what is listed when they have lower profile tires. If it was my car I would run in the 36-40 psi range.
Old 04-14-04, 09:05 AM
rominl
exclusive matchup
rominl's Avatar
well you will be fine with 34, more comfortable. but i don't wanna bend my rims, so i run 40
Old 04-14-04, 11:20 AM
mrshabo
mrshabo's Avatar
hrm thanks for the info if you run 40 psi wouldn't you raise your chances of getting bubbles in your tire?
Old 04-14-04, 12:31 PM
AutoCoutureSC
AutoCoutureSC's Avatar
im with henry on this one. I run 40 on my 20's and my 19's
Old 04-14-04, 01:28 PM
rominl
exclusive matchup
rominl's Avatar
well right now i still don't have any bubbles on my tires, so fingers crossed
somehow i had a feeling that with less air pressure you get bubbles more easily. maybe i am wrong on this one though
Old 04-14-04, 02:20 PM
JacobT
JacobT's Avatar
Any quality radial tires should not bubble. The only situation you'll get bubbles is due to the broken metal mesh layers. I usually put 42 lb for my 20's for better gas millage and rim protection. The max tire pressure on the side wall is 50 lb so you really don't have to worry about getting bubbles on your tires.
Old 04-16-04, 05:58 PM
PHML
Master Thread Closer!!
PHML's Avatar
48 psi all around....still under the 51 psi max.
Old 04-16-04, 10:41 PM
rominl
exclusive matchup
rominl's Avatar
damn, that's so high pressure! why?
actually you might wanna be more careful, you are stretching it bad. tires heats up during driving and the psi inside get higher by 3-5psi. if you measure it 48psi when hot then you are ok, otherwise if you measure it when the car has been in the garage overnight, i think that's too high
Old 04-19-04, 09:48 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
WOW! I am only running 33 psi in the front and 31-32 psi in the rear on 19's. I tried 38psi, but the ride felt horrible and harsh.
Old 04-19-04, 10:57 PM
mrshabo
mrshabo's Avatar
40 psi it is.
Old 04-19-04, 11:05 PM
GS430 GUY
GS430 GUY's Avatar
I am running 35 PSI on my 18" HRE's here in NY right now. I usually keep it btwn 35-37 PSI. Eventually after I clean my rims up real nice I'll up the PSI to 37 myself.
Old 04-20-04, 12:32 AM
rominl
exclusive matchup
rominl's Avatar
yeah it's harsh, but it would be even worse on my wallet when i bend my hre
Old 04-21-04, 07:58 PM
Wald GS
Wald GS's Avatar
Then again, I am a safe driver.
Old 04-22-04, 07:18 AM
Gojirra99
Super Moderator
Gojirra99's Avatar
I keep them at 35 (cold) for both my Lexus and Infiniti, they'll be at ~38 after running for a while, is that not safe enough ? Roads here are generally quite good, and I'm fortunate enough not to have ever bent a rim yet.
Quick Reply: Correct psi per tire? (19)
