rim width, lip, offset on 2nd Gen GS
Old 04-13-04, 10:28 PM
rodel
rodel's Avatar
Default rim width, lip, offset
For 2nd Gen GS owners...
If anyone is rolling on 8.5"+ (front), 9.5"+ (rear)...
What's the width of your rim? How wide are the lips? what are the offsets? Did you have to roll the fender?
Please post pics of your rims. Thanks.
Rodel
Old 04-13-04, 10:34 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,127 Likes on 1,297 Posts
Rodel,
We have a specific forum for wheel questions.... I'm moving your post there
Old 04-13-04, 11:06 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: rim width, lip, offset
Rodel
1) conflict, you asked if anyone is running 8.5 and 9.5 and then you asked what's the width of the rims. the answer would be 8.5 and 9.5?
2) the size of the lip doesn't really have too much to do with the overall width, at least not directly related. it's more dependent on the design of the wheels
3) if you get the right offset, you don't have to roll fenders
4) i already have the faq as a sticky on the top of the forum on all the sizes and offset
Old 04-13-04, 11:10 PM
rodel
rodel's Avatar
Default Re: Re: rim width, lip, offset
1. I asked for rim width because I stated "8.5+" and "9.5+", not just "8.5" and "9.5"
2. Width of the rim and wheel offset will affect the width of the lip
3. Just like #3, width of the rim and offset will determine if you have to roll the fenders
4. I saw recommendations on http://www.lexusgonewild.com/WheelFitment.shtml
however, I wanted to know individual setups of owners that actually have the wheels installed on their GS.
Old 04-13-04, 11:44 PM
jtanoyo1
jtanoyo1's Avatar
Well I got approx. 10cm of lip in the back with 19x10 +24 and super low disk setup /w my autocouture. But I know if you buy something like Garson wheels with the same setup you will get A LOT more lip.
Old 04-14-04, 12:43 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: Re: rim width, lip, offset
i have 8.5 and 10
like i said widths and offset determine part of the lip, but the major part is still the wheel design. i have 2" in the front (still clear big brakes) and more than 3" lip in the back, but that's the max you can get with hre (with no mod). if you go with gettins 10 in the back, you can get 4" with super low disk. if you go with low disk gettins in the front with 8.5, you can still get around 3" of lip. and that's with offset HIGHER than my hre already. so you can see offset has little in determining the lip size
Old 04-14-04, 05:47 AM
ted920
ted920's Avatar
I have new wheels coming w/in next 2 weeks and they will be 20X8.5 in front with a 2.5" lip and 20X9.5 in the rear with a 3.5" lip. Offset is 40 for both.
Ted
Old 04-14-04, 11:04 AM
rodel
rodel's Avatar
When you guys are referring to "lip,"
1. are you measuring the distance between the edge of the face of the wheel to the outer edge of the wheel?
2. Or are you measuring the distance between the inner edge of the lip to the outer edge of the wheel?
There is a difference. For example let's take wheel A and wheel B. Wheel A and B supposedly have 3" of lip. However,
1. wheel A's face extends 1" over the lip, towards the edge of the wheel.
2. wheel B's face extends 2" over the lip, towards the edge of the wheel.
Technically speaking, wheel A has 2" of "real" lip. Wheel B has 1" of "real" lip. Rominl, I believe this is what you're referring to when you state the the amount of lip really depends on the wheel design.
Rodel
Old 04-14-04, 01:27 PM
rominl
exclusive matchup
rominl's Avatar
i guess usually people refering to the actualy width of the physical lip, regardless of how much the center sticks out. so you stick a ruler to the lip and measure from the inside of the lip to the outside of the wheel.
for me it's a bit more than 2" in the front and a bit more than 3" in the back
Old 04-14-04, 08:52 PM
V8_Aristo
Bippu
V8_Aristo's Avatar
Had 18x8.5 and 18x9.5 with 41 offset, thought they were too small in diameter and set in a little too deep.
Old 04-17-04, 08:21 AM
rodel
rodel's Avatar
Here's to further clarify my point of the wheel's center, hanging over the lip. Contrary to what most people say, I consider this wheel to have only 1/4 of it's lip. The wheel center hangs over 3/4 of the lip. If I placed a disc over the wheel center, this wheel would have almost no lip.
On the other hand, the center of this wheel hardly hangs over the lip. I consider this wheel to have "true" lip.
Old 04-19-04, 02:29 AM
rominl
exclusive matchup
rominl's Avatar
ah gotcha, yeah i agree with you. my hre doesn't have those hang over, so i am truly 3"
Old 04-21-04, 11:20 PM
rodel
rodel's Avatar
We're finally eye to eye on this topic. I see pics where people put a $1 bill over the lip to show off. In many pics the center of the wheels hangs over most of the $1 bill. My reaction is
2FiVE8
12-30-06 05:02 PM
punch10
04-27-06 12:40 PM
minh
12
10-09-03 06:41 PM
D2-AUTOSPORT
02-21-03 02:38 PM
Quick Reply: rim width, lip, offset on 2nd Gen GS
