shaking at 55 and above
Old 11-17-04, 03:46 PM
lexsc3
lexsc3's Avatar
Default shaking at 55 and above
my car shakes sometimes at 55 and above, its not all the time though its depends on the surface and slope to the side of the road.....i was wondering if the problem would be alignment or just an unbalanced tire?.....i hit something a couple weeks ago from some dumb-***'s truck who didnt care to tie it down
Old 11-17-04, 03:57 PM
mikeloc24
mikeloc24's Avatar
You may have lost a magnet when you hit that debris, so you'd need to get your tired re-balanced. That would be my guess. If it were the alignment the car would pull to one side no matter what speed you were going. Just my opinion though.
Old 11-17-04, 04:00 PM
lexsc3
lexsc3's Avatar
is there a way i can figure out which tire need balancing....i dont want to have to pay to get all of them balanced again.
Old 11-17-04, 04:07 PM
SwampFox
SwampFox's Avatar
magnet?
Old 11-17-04, 04:15 PM
lexsc3
lexsc3's Avatar
i think he just meant a weight that they use to balance it
Old 11-17-04, 10:10 PM
SC300Es
SC300Es's Avatar
It's most likely your front tires. The rear tires don't cause as much shaking as the fronts.
Have both fronts looked at. It doesn't cost that much to balance them anyway. $10 each?
Ed
Old 11-18-04, 05:27 AM
lexusk8
lexusk8's Avatar
SC300ES is right. Balancing in the fronts is more needed than in the rear set. I'd pay to do just the fronts first, and if shaking still appears, then do the rears. Balancing at my local tire shop is about $11 per tire, and you can also get it done at Sears, Costco, etc.
Old 11-18-04, 10:03 AM
Lexusfreak
Lexusfreak's Avatar
Cool
Agreed! it's best to try the easiest possible problems to eliminate the cause. It is possible that it could be a combination of balancing & alignment should you still feel a problem thru the steering wheel. Let us know.
Old 11-18-04, 11:27 AM
BA_GS400
BA_GS400's Avatar
If you look very closely on the outside and 'inside' rim edges, you can usually tell if a wheel weight has fallen off because the rim is generally shinier in that spot, and frequently outlined ever-so-slightly with very thin line of dirt.
Old 11-18-04, 11:57 AM
mikeloc24
mikeloc24's Avatar
Correct. Start with the simple fixes first, then go for the more complicated ones if those don't work. Drop the $20 at a tire shop for them to balance the fronts and hopefully this solves the shaking issue. Good luck.
Old 11-18-04, 04:04 PM
SwampFox
SwampFox's Avatar
EXCELLENT
shyvpboi
Maintenance
12-16-03 12:59 PM
aldo23
01-13-03 02:35 PM
newyorker
11-28-02 03:30 PM
EastCoastES
11-17-02 01:24 AM
gsnav
04-10-02 08:30 AM
Quick Reply: shaking at 55 and above
