trouble buying 20's.....
Old 03-21-04, 09:15 PM
tuterz
tuterz's Avatar
Default trouble buying 20's.....
did any of you guys have trouble finding 20s that would fit the car... i try to order some today... and the guy i talked to said they didnt carry and rims that fit the ls because of the offset of it.... im driving a 1992 ls...hope you guys can help me... thankz
Old 03-21-04, 09:32 PM
tuterz
tuterz's Avatar
oh and... one more thing.. wat is a recommended tire size?.. thankz..
Old 03-23-04, 08:40 AM
gewe21
gewe21's Avatar
pm GS4Will... he should be able to help you
Old 03-23-04, 01:56 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
You're definitely going to have some rubbing issues with the inner wheel wells and also possibly with the fenders. You'll need to get some fender rolling/shaving done as well as either modifying (recommended) or removing the inner wheel well plastic lining (not recommended) in order to fit the 20s without any rubbing issues. If you can get all of that done, I'd suggest using tires with the thinnest sidewall...245/35/20 for the front and 275 (or 285)/30/20 for the rear (if you're going for the staggered setup)
Old 03-26-04, 08:45 PM
JDM SC4
JDM SC4's Avatar
what tires have the thinnest sidewall? i know the NT555 are pretty thick...
also, other than getting dirty when removing the the wheel well, what else can go wrong besides the obvious? sorry for a dumb question , please, no flaming...
Old 03-26-04, 09:35 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Dunlops SP 9000's have thinner sidewalls than other brands, such as Michelin, which I'd say is more of a beefier tire. Problem with having a thinner sidewall is that you're more prone to damage your wheels when driving over potholes/bumps.
There's no such thing as a dumb question on the forums, so don't worry about getting flamed. Removing the plastic lining in the wheel well could result in rusting of the metal parts that are covered by the lining over time, unless you don't mind the possibility of something like that happening...it's your call.
Old 03-30-04, 10:38 AM
DXC
DXC's Avatar
Default Re: trouble buying 20's.....
20"... so many people have it on, at least in sunny CA... e-mail me so I can send you some pictures if you are interested (don't know how to post pictures on this forum - new member).
LEXJG
12-13-13 12:40 PM
jea
12-20-10 04:35 PM
GS3Tek
07-02-08 11:57 AM
Shlinyo
Canada
04-27-06 06:05 AM
SC300FLYINBY
SC- 1st Gen (1992-2000)
08-23-02 03:50 PM
Quick Reply: trouble buying 20's.....
