Problem with TT brake
Old 03-13-04, 05:11 AM
ChronoJ1
ChronoJ1's Avatar
Default Problem with TT brake
I'm in the process of purchasing a set of used Supra TT brakes from a supra forum member.
However, he states that there is a minor problem with it, AFTER he takes the money through Paypal.
Is it really 'minor' as he says? Here's a pm from him.
i wanted to check with you before sending them out, when i pulled the right caliper off, i found that it was leaking a small amount of fluid. it needs 2 small rubber O-rings that seal the 2 sides of the caliper. it's a very easy fix, just need to get the O-rings.
Old 03-13-04, 05:14 AM
nextlevelcoupe
nextlevelcoupe's Avatar
after the transaction? sounds suspect to me.....
Old 03-13-04, 08:16 AM
JacobT
JacobT's Avatar
The caliper needs to be rebuilt with new seal rings. Any brake shop can do it for a little fee
Old 03-13-04, 12:19 PM
ChronoJ1
ChronoJ1's Avatar
So this can be done at any common Joe's Garage?
Old 03-13-04, 03:05 PM
D-MAN63
D-MAN63's Avatar
Thats a shady business guy.... Hope everything goes well.
Old 03-15-04, 11:23 PM
SexyRed
SexyRed's Avatar
This is the perfect opportunity to get the calipers powder. It should cost $25 per caliper to powder coat plus sand blasting labor charge. The rebuild kit cost $17 from Champion Toyota in Tx.
ASk for Jeff Watson, 800-327-2087. He has great prices.
Tell him Danny Lai from CA sent you.
Danny Lai
I wouldn't call it shady business, it is unexpected circumstances. Rebuilding the pistons ensures that the brakes are "new".
Old 03-24-04, 12:52 PM
mrshabo
mrshabo's Avatar
I wouldn't worry too much about it, rebuilding the seals is not a uncommon thing. It isn't expensive to do and it's a pretty easy job. I'd ask for him to give you some money back cause redoing the seals is more money out of your pocket
redlex15
Suspension and Brakes
27
12-01-12 07:23 PM
shaitaan
11-21-06 06:16 PM
AME_VIP
08-02-06 08:08 PM
Quick Reply: Problem with TT brake
