rotor question?
Old 03-14-04, 01:48 PM
tool24
tool24's Avatar
Default rotor question?
i have a rusty rotor on my 99 rx300 with 76000 milies. I am thinking of replacing my brake pads? Should i also replace the rotor? When is the right time to change the rotor?
Old 03-14-04, 02:13 PM
Carpe Diem
Carpe Diem's Avatar
Not meaning to be a wise guy, the answer is when it needs it. There only two reasons to replace a rotor, either it's warped (you'll feel some come and go surging when you step on the brakes) of it's been worn below the allowable thickness.
If its not warped and not seriously grooved then just put on the new pads and they'll fit themselves to the rotor. If its seriously grooved then you can have it resurfaced if there's sufficient thickness remaining (your machine shop will check for this when you take it in) or replace it.
The rust you see is on the rotor hub and has no bearing on brake performance. If you don't like it, try painting it with hi-temp flat black paint.
George
jimjaix
06-12-13 01:50 PM
chuckie81
12-03-12 08:46 PM
dale386
GS - 1st Gen (1993-1997)
02-15-12 12:27 PM
SilverSprt
RX - 1st Gen (1999-2003)
08-19-07 10:51 PM
rickaustin
07-10-06 04:16 PM
Quick Reply: rotor question?
