For those with 19"+ wheels...
I did an extensive search on the subject, but couldn't find any definitive answers. I know there is much speculation as to why/how GS's chew up 17" or larger tires so fast. I just want to know the following:
1) Wheel/tire combo you have?
2) Suspension modification(s), if any?
3) How many miles you're getting on the tires from question #1?
4) What kind of unusual wear you get on your tires?
5) How often do you get alignments done to try to preserve the life of your tires?
6) Wheel balancing issues?
I'm just trying to put together some quantitative data together so I can attempt to see if the looks of 20's on my GS4 justifies the amount of money I will be dumping into a wheel/tire setup. Thanks guys. I appreciate any input that you have.
exclusive matchup
you get bonus i had 19s and now 20s
19s
1) volks av3 19x8.5 19x9.5, with yoko avs sports, so3, and continential
2) tein HA, and then tein flex
3) yoko was horrible, 15k and bald. so3 was good, still like new when i sold the wheels. continential it was totally new when i sold the wheels
4) on my yoko, wear on the inside. on the other two, no uneven wear
5) alignment once every 6 months to a yr
6) balanced my wheels when bought them and every time tires mounted, nothing else. all good
20s
1) hre 540r 20x8.5 20x10, perelli pzero nero
2) tein flex
3) so far so good, 2k miles and everything perfect, can't even tell the wear
4) no uneven wear
5) alignment just done today
6) balanced it when bought the rims, that's it
19s
20s
2) tein flex
4) no uneven wear
here are my answers...
1) Junction Produce Scara Japans 19x9 - 19x10 / Yokohama DNA-Grand Prix (japan only tire) 225-35-19 - 235-35-19
2) Tein HA
3) I have had these tires since Oct. 03 and I have driven it at least 2500 miles since
4) none so far...
5) I haven't aligned it since I put on these wheels and tires. It seems to be ok. =)
6) my front wheels seem to be off. They are balanced, but at 60mph it shakes, faster or slower, it doesnt shake at all... weird...
2) Tein HA
4) none so far...
lexcapade, I have been into cars since 1970, Hot Rod and Custom Cars my whole live, Even if everything on a car is right some cars are just very hard on tires and there's not any thing to can do . When you run a staggered set-up you then loose your tire rotation which is really need for tire life................But some tires are better than others you just have to play around............it is a hit and miss game..........The wheel centerbore is very very important a must for wheels the half-a$$ adapters is a bad idea.......when spending high dollars on wheels they need to fit right !
Loves Snickerdoodles!
1) IForged Flux: 20 x 8.5, 20 x 10 - tires: Bridgestone S03's F - 245/35/20 R - 285/30/20
2) Eibach Pro-Kit lowering springs
3) So far I've put 6000+ miles on them
4) Slight wearing on the inside of the front tires - nothing that an alignment couldn't fix. Rear tires seem to be weaing evenly.
5) I've never had the car aligned.
6) No balancing issues here.
Former Sponsor
1. 20x8.5 DVS Wrath (ghetto dub), 20x8.5 Dronell CA-05, 255/35-20, 2new sets of Falken GRBfk 451
2. INTRAX springs/KYB struts (1.9 drop settled)
3. Put about 10k on the first set
4. With bad rear camber-wore the rears out before 10k, fronts were fine.
5. Got the car aligned after the drop (shop didnt do a good job in the rear, thus #5), after the second set of
wheels/tires, got the car realigned, and NO uneven rear after about 5-6k miles
6. No balancing issues, just make sure the shop has good balancing equipment
1. Zauber Gettins: 20x8.5-20x10 Brigdestones so3's 245/35/20-275/30/20
2. Teins cs coilovers
3. had the set up since June 03" and must have about 11k miles or so at least
4. inside wear on the front tires..noticed about 2 months agao and flipped front tires 2 other side
5. car has been aligned 3 times
6. none...
i had a negative camber in the front , thats why my fronts wore so fast...i raised it now 2 a even camber front and rear so i'm good 4 now, just need 2 replace the front tires soon....
6. none...
Re: For those with 19"+ wheels...
[1) Wheel/tire combo you have? AT Rivas 19 x 8
2) Suspension modification(s), if any? UGO STB's
3) How many miles you're getting on the tires from question #1? 500 so far
4) What kind of unusual wear you get on your tires? None
5) How often do you get alignments done to try to preserve the life of your tires? When new tires were put on
6) Wheel balancing issues? Balanced on New Hunter machine!! No Problems...
1) 19x8.5-19x10 Zauber Gettins on Falken Azenis ST115 F:245/35/19 R:275/30/19
2) Teins CS Coilovers
3) So far about 8-9K since end of July 03
4) Fairly even, still a good amount of tread left
5) Once when I had the wheels put on
6) Wheels came balanced. Just redid the balancing as of today - removed any steering shudder I was feeling.
Thanks for the replies guys. Seems like most of you aren't having any major problems in terms of abnormal tread wear. That's a plus. So, from what you guys have told me, I feel fairly comfortable with my decision to go with 20's... Now just need to find that perfect wheel....
Former Sponsor
do you want 5spoke, 6spoke, mesh, etc etc?
I'm really into 5-spoke or 6-spoke designs. To me, these scream out "CLASS." I don't want to spend more than $2k because my driving route to work ALWAYS has construction going on. Plus the roads aren't in the greatest shape anyway. I really like the centerline stingrays, but they don't make them in a bolt pattern to fit our cars. I liked these because they're forged, and light (20"/~20lbs). Still need to keep shopping though. I saw at www.victoriatire.com, they had some 20" package specials from $1700+, but I need to do some more investigation on the quality of those combos at those prices... By no means will I rush into it and do an impulse buy. I'll just roll on the stock chrome 16's till I find the "perfect" wheel for me... well, i'll start rolling on the stocks when my car gets delivered to me on Sunday....
Former Sponsor
you didnt mention chrome or not but 20" chrome with tires is gonna be a tough find at best for 2k. There are 2 sets of chrome 20s in the classifieds with tires right now though all are under 2k (used)
I dont personally know these sellers or anything, just figured I would point out a few deals circulating! Good luck man
these are down to 1600-1800 i think
these are 1400 with new Toyo T1-S (really good price)
these are 1800
these are 1800
theoryguy
07-16-15 12:04 PM
EyesOnly
Wheels, Tires & Brakes Forum
11-24-05 02:32 AM
