Will This Set Up Work On IS300 ?
Old 02-02-04, 11:58 PM
evolon5150
evolon5150's Avatar
Question Will This Set Up Work On IS300 ?
Front
18x8.5 with +37 offset / Tires 225/40/18 or 215/40/18 depending on fitment problems.
Rear
18x9.5 with +43 offset / Tires 235/40/18
This is going on a 2001 IS300. Also will have any rubbing issues with this setup?
Thanks in advance for any help.
Old 02-03-04, 12:16 AM
mr who
mr who's Avatar
You will absolutely have rubbing issues. Probably both front and back. From the sizes...seems like youre buying a used set of wheels that were on a different type of car...cause I don't think any wheel shop would recommend you buy those sizes brand new
Old 02-03-04, 12:48 AM
GS4Will
GS4Will's Avatar
too wide..what mr.who said
Old 02-03-04, 12:49 AM
rominl
exclusive matchup
rominl's Avatar
too wide and the offset are too low. forget it
Old 02-03-04, 07:57 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Sizes
Not too wide but the offsets are low. It might work with some modification there are some guys at IS300.net that run pretty low offsets.
Old 02-04-04, 07:26 PM
alredxiii
alredxiii's Avatar
This might help you out on your quest
is300.net
This is from Lexus_IS300
front
width | offset | tires range (width)
x7 = 40 and up 215-225
x7.5 = 42 and up 215-235
x8 = 43 and up 215-235
x8.5 = 45 and up 215-225
rear
x7.5 = 40 and up 215-235
x8 = 42 and up 215-245
x8.5 = 45 and up 225-265 (255-265 requires rolling or shaving lip)
x9 = 49 and up 235-275 (MAY require rolling or shaving lip)
x9.5 = 52 and up 245-285 (MAY require rolling or shaving lip, 285 may require more modification)
x10 = 45 and up 255-315(requires pulling fender)
Greenspeed
11-22-10 04:59 AM
dcz
10-16-07 09:09 AM
Sceptre
IS - 1st Gen (2001-2005)
17
04-08-07 05:28 AM
AKY
01-10-06 10:41 AM
dragion
07-28-02 12:36 AM
Quick Reply: Will This Set Up Work On IS300 ?
