tire size and offset help
Old 01-23-04, 10:30 AM
ksmith
ksmith's Avatar
Default tire size and offset help
What size tires and offset would work best for
a 99gs 400
I will have 20 x 8.5 front
and 20 x 10 back
The know that offset will be important as I am moving f
from a '19 wheel to a '20 wheel.
The car will be lowered using Tein coilovers.
Thanks for your help
Old 01-23-04, 11:14 AM
rominl
exclusive matchup
rominl's Avatar
if you wanna play safe, go with 38 fronta nd 44 rear.
tires, 245/35 and 275/30
Old 01-24-04, 10:48 AM
Lettuce
Lettuce's Avatar
could you stil have car lowered at least 2 inches with that type of offset and tire?
Old 01-24-04, 05:35 PM
rominl
exclusive matchup
rominl's Avatar
if you are on 19, yes, no problem. if you are on 20s, if you lower it to 1/2 finger gap or no finger gap, you will rub the top of the front fender
Old 01-24-04, 10:25 PM
Lettuce
Lettuce's Avatar
So what would be the proper offset for 20x8.5F and 20x10R? I have adjustable suspension I would like to at least have 11/2 drop with that wheels setup. thanks
Old 01-26-04, 02:48 AM
rominl
exclusive matchup
rominl's Avatar
well it's not about offset anymore, it's about the out of spec wheels setup. check with synergy and jawnthen if you want, they have that issue, and as long as you have 20s with low enough drop, you will get that
Aweera
12-10-22 01:50 PM
rhizzz
ES - 6th Gen (2013-2018)
03-24-14 03:53 AM
blacklexgs
05-10-11 02:42 PM
B_Cruz
01-15-04 11:58 AM
Quick Reply: tire size and offset help
