help me decide on shoe size
Old 12-08-03, 08:29 AM
B_Cruz
B_Cruz's Avatar
Default help me decide on shoe size
Planning on getting new shoes for my GS400 and I was wondering if someone can direct me in the right direction before I make my purchase....
I am going with a staggered set up.
Fronts will be 19x8.5 and the rears will be 19x9.5.
Should I go:
Front: 235/35/19
Rear: 265/30/19
or
Front: 245/35/19
Rear: 275/30/19.
Offset are as follows:
fronts: 35, 40, 45 MM
rear: 40, 45 MM
Thanks in advance!
-Byron
p.s. will be getting L-Tuned suspension or Tein lowering springs.
Old 12-08-03, 08:43 AM
rominl
exclusive matchup
rominl's Avatar
to avoid any possible rubbing, i would do
19x8.5 +40 front with 245/35/19 (+35 should work, but it's up to you)
19x9.5 +40 rear with 275/30/19
Old 12-08-03, 11:34 AM
B_Cruz
B_Cruz's Avatar
thanks for the reply and help rominl.
so whats the difference with the 35 and 40? 35 stick out more or less than 40?
Thanks again,
Byron
Old 12-11-03, 10:07 AM
PHML
Master Thread Closer!!
PHML's Avatar
35s are lower profile than 40s....the profile has nothing to do with "sticking out". Sticking out is reflected by the width of the wheel, the offset, and the tire width (ie 245 or 275) in your case.
Pete
Old 12-11-03, 10:24 AM
rominl
exclusive matchup
rominl's Avatar
Thanks again,
Byron
no that's the profile. the higher the number the thicker the tire is. it's an ratio (35% or 40%) of the width of the tire
Old 12-11-03, 12:31 PM
JacobT
JacobT's Avatar
I believe Byron was talking about the offset
+35 sticks out 5 mm more tha +40. I 'd go with 35 front.
Old 12-16-03, 07:48 PM
B_Cruz
B_Cruz's Avatar
yes I was. sorry for not being clear. I was asking about the offset.
Old 12-16-03, 09:53 PM
bluelex
bluelex's Avatar
35 will b outmore and 40 will b in more...offset wise
vinnier6
04-03-16 09:13 AM
Napalvr
01-16-15 06:28 PM
Rider
IS F (2008-2014)
01-19-12 07:48 PM
klthomas
10-26-06 06:55 AM
ILOVEGIRLS
04-17-06 10:23 PM
Quick Reply: help me decide on shoe size
