18"
18"
Would increasing wheel size to 18" on my GS300 decrease performance?
I have heard that larger wheels tend to make the car loose it's perfromance to an extent.
Although the GS300 is midly underpowered would it be able to still put out what it can.
would I have to upgrade brakes?
what type of tires could I be expecting to stick on?
I am looking at some 18" TRD rims.
Originally posted by DGOT20s
WOW those look really nice in chrome. I dont think 18s will hurt your performance too much
Former Sponsor
to be totally honest I dont think going to a 235/40-18 will hurt any of that stuff very much. I guess you need some 18" owners to chime in here!
Those wheels look SOO different in chrome though
The One
Originally posted by camtrek
I made a promise to myself that I wouldn't go beyond 17" but the rims are friggin sweet. Performance is my main priority. I have read in the other threads that my OD and SPeedo may be thrown off. Will I have a problem?
Originally posted by Neo
Odometer and Speedometer should not be off much if you get the right tire size so that the Outside Diameter of the wheel/tire is about the same as the stock size. Performance-wise, it will depend on the wheel. Mostly it is weight. My buddy has the same wheel (not chrome though) on his SC and he said that the rim was very light. If that is the case, then you will have minimal performance degradation (if any) with these wheels. Now the chrome may add some weight so I am not sure.
I have 235/55/R16's now, could you perhaps tell me what tyre would be my best bet to go with these rims?
The One
Another thing to consider is that the 255 is not a "normal/popular" config so you'll find less options in buying tires. The 245/40/18 has more selection.
Do you know the offset on these rims? With your 235/55/16, your outside diameter is 26.2. You can safely run 245/40/18 all around. This gives you an OD of 25.7. The closest you can get is with 255/40/18 with OD of 26. Since these wheels are 9s, you can easily fit this tire plus it should work in the rear. I am not sure about the fronts. You can do a little search to see what people running 9s up front are running as their tire size. (I am assuming you want to keep all 4 the same for rotation purposes.)
Try the calculator out. It should answer all your questions about size.
The One
Originally posted by Blanco
Ok, I'm assuming your stock GS3 is running something like 225/55x16", and you want 18's same size all the way around?? I have 18's, but I run staggered. I run 245/40x18 up front. After upgrading from stock 16's on my GS400, I wouldn't do anything smaller than the 245/40x18 all the way around. And according to my tire size calculator You'd only be changing the speedo reading by .1% down. That is when your speedo reads 60mph, your actually travelling at 59.9mph.
