fitment question 19in wheels
a member is selling a set of manaray sport wheels, he has a 19x9 +45 front and 19x10 +37 rear, Im concerned about the rear offset will this work on a 98 GS400? his car is a sc400.
thankyou for your reply in advance!
I had the same question. Here was Rominl's excellent response
Originally posted by rominl
the rear will be very marginal. 19x10, usually people get around +42 (a bit aggressive) or +44 to be save. with +37, you will most likely have to cut of shave fender for sure.
the front i think might be ok. i know for HRE, getting 8.5 with +32 offset would work no problem (on the aggressive side), so if you push the extra 1/2" to the inside it would be +44 offset. but i am not sure if you are going to hit anything inside. worst of all, i guess, is when you turn the wheel to full lock and back up the car you will rub a bit
