Folding @ Home - Let's find a cure for cancer - Page 54 - Club Lexus Forums
Thread Tools Search this Thread
Old 08-12-07, 07:03 PM   #796
cpone
There can only be One
cpone's Avatar
Quote:
Originally Posted by Hi im SHON View Post
i have that folding@home thing on my ps3, but never knew what it was for !
Set it up to run for Club Lexus man!
If you need help setting it up. Let me know. I'll walk you through it.
cpone is offline   Reply With Quote
Old 08-12-07, 07:07 PM   #797
cpone
cpone's Avatar
Quote:
Originally Posted by Ramon View Post
I guess I should have read the instructions a bit more carefully... I had missed a step in the installation process, but now have the SMP client working on my dual core. The latest beta release of the GPU client is also much improved over the last one I tried, my windows GUI is still very responsive even with it running.
Make sure its split with about ~25% cpu split 4 ways.
Do this by looking at your task manager and seeing the processes.
If you need help setting it up as a service so you never have to worry about it again. Let me know. I have it set up on multiple computers this way.
WELCOME TO ALL THE NEW FOLDERS.
AND THANKS!
LETS KICK SOME A$$!
Old 08-12-07, 07:20 PM   #798
Ramon
Well after doing a bit of research on SMP vs GPU, I've decided to completely ditch the GPU client and stick with SMP. Very little difference in PPD, and the SMP client uses significantly less power (80 watts less on my system) and produces less heat than the GPU client. Not to mention, if I want to do anything that requires GPU power like play video games or watch any hardware accelerated video's I have to manually stop the GPU client from running, then manually start it again versus the SMP client which will seamlessly give up any cycles you may need.
Ramon is offline   Reply With Quote
Old 08-12-07, 07:28 PM   #799
cpone
cpone's Avatar
Good choice Ramon.
Thanks again for joining the team!
Old 08-12-07, 07:40 PM   #800
DaveGS4
Forum Administrator
DaveGS4's Avatar
Congrats to CPone, the first CL team member to cross 300,000 points
We should break 400 as a team this week
Anyone with a dual or quad core machine please run the SMP client if you can, it makes a HUGE difference
DaveGS4 is offline   Reply With Quote
Old 08-12-07, 07:55 PM   #801
cpone
cpone's Avatar
Damn I did not even notice.
Thanks Dave!
Old 08-12-07, 08:05 PM   #802
Ramon
So which other forums are we competing with anyway?
Old 08-12-07, 08:10 PM   #803
brentpresl
brentpresl's Avatar
US.
:biggrin:
brentpresl is offline   Reply With Quote
Old 08-13-07, 07:07 AM   #804
Hameed
CF fanatic
Hameed's Avatar
I guess it's time to ditch the console version on my dual core eh?
I have two instances of it running on this pc and one WU is 96% done while the other is 42% done. I don't want to lose either, so what is the best way to start using the SMP client as opposed to the console versions I am running currently without losing the work completed on both of the units?
Hameed is offline   Reply With Quote
Old 08-13-07, 07:22 AM   #805
DaveGS4
Forum Administrator
DaveGS4's Avatar
I'd let the 96% finish and send. From what I've read, you can back up the files and move them to another computer for the other... will see if I can find 'em.
Edit - this is meant for a different purpose (disconnected folding PC) but tells you how to move the work http://fahwiki.net/index.php/Sneakernetting
Old 08-13-07, 07:52 AM   #806
DaveGS4
Forum Administrator
DaveGS4's Avatar
Our two biggest competitors are the XCPU folks (Brent and co) who are beating the pants off of us right now on PPD... We have more members but they have more folks using quad / dual / overlocked PCs running big point SMP stuff. Similar to the HardForum you post on but smaller.
The second competitor (when we started this) is MBWorld (ranke 291). http://folding.extremeoverclocking.c...php?s=&t=45431 They have a HUGE lead over us having folded for about a year before we really got active but we're slowly catching up to them and should be even in about a month and 1/2.
Another car forum I see out there in front of us are Audiworld (rank 210)
http://folding.extremeoverclocking.c...php?s=&t=35021
Old 08-13-07, 08:04 AM   #807
cpone
cpone's Avatar
Hameed I did the same thing Dave said.
Let the work unit finish out on the 96% one and just drop the 42% one.
Screw it.
You'll get more points from the SMP anyway.
That 96% should be done in like another 3 hours anyway so get cracking on setting up your SMP.
Old 08-13-07, 08:18 AM   #808
Ramon
Dave, are you stalking me?
Old 08-13-07, 08:54 AM   #809
DaveGS4
Forum Administrator
DaveGS4's Avatar
Don't take it personally... I stalk EVERYBODY
Old 08-13-07, 09:54 AM   #810
Hameed
CF fanatic
Hameed's Avatar
Screw it.
Ok all done.
1. Now do I need to run the previous fah console version setup to set it so that it does not run as a service anymore so that it is effectively un-installed?
I just killed the command window for the second instance of the console as that was not running as a service anyway.
2. How do I see the "progress" of the SMP client? I looked in the install folder but don't see a unitinfo or log file....
Edit, figured out the answer to my second question.
Here is my log file output:
[17:00:31] *------------------------------*
[17:00:31] Folding@Home Gromacs SMP Core
[17:00:31] Version 1.74 (March 10, 2007)
[17:00:31]
[17:00:31] Preparing to commence simulation
[17:00:31] - Looking at optimizations...
[17:00:31] - Couldn't open work/core78.sta for writing.
[17:00:31] - Created dyn
[17:00:31] - Files status OK
[17:00:42] - Expanded 2973371 -> 15200001 (decompressed 511.2 percent)
[17:00:43] - Starting from initial work packet
[17:00:43]
[17:00:43] Project: 2653 (Run 17, Clone 42, Gen 4)
[17:00:43]
[17:00:43] Assembly optimizations on if available.
[17:00:43] Entering M.D.
[17:00:59] iles
[17:00:59] - Starting from initial work packet
[17:00:59] Could not touch
[17:00:59]
[17:00:59] Project: 2653 (Run 17, Clone 42,
[17:00:59] Project: 2653 (Run 17, Clone 42, Gen 4)
[17:00:59]
[17:00:59] Entering M.D.
[17:01:06] Couldn't open Go file
[17:01:06] _IO_ERROR
[17:01:06] Finalizing output
[17:03:06] FILE_IO_ERROR
[17:03:06] Finalizing output
What the heck does that mean now? It seems to be stuck and does not go any further.
On top of all this I have four processes called FahCore_a1.exe running now. Between the four of them, they are pretty much using up 100% of the processors.
Thread Thread Starter Forum Replies Last Post
Land Rover Discovery Sport Hoovey2411 Car Chat 49 06-21-16 12:11 PM
Inside Lexus LFA Works via Motor Trend Magazine..!! Tons of new pics inside!! Joe Z LFA Model (2012) 18 02-21-13 03:25 PM
First Drive: 2013 Ford Flex Hoovey2411 Car Chat 9 03-25-12 12:48 AM
My GS brothers and sisters, I need you to help FOLD at HOME! LexFather GS - 2nd Gen (1998-2005) 3 08-25-07 05:13 PM
Folding @ Home... Let's Find a Cure for Cancer! Buds IS - 2nd Gen (2006-2013) 6 11-17-06 04:23 PM
Tags
cancer, change, club, cureforcancer, folding, folding @ home, foldinghome, home, images, lexus, p2611pope, p2613tethered, progress, ps3, username, vesicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
