Suspension Springs, shocks, coilovers, sways, braces, etc.
Front Camber
Old 09-24-15, 07:34 PM
sam430
sam430's Avatar
Default Front Camber
Anyone know where to get camber adjustment for the front?
Tdemand or dominant Engineering? where to order or how? I can't drive around with all this camber. It makes the car erratic on bumps.
Old 09-26-15, 02:10 PM
sam430
sam430's Avatar
Anyone know if we can use the whiteline camber bolt? Some kind of positive insert in the bushing? This negative camber sux!
http://www.whitelinesuspensionparts....ment-parts.asp
Old 09-28-15, 08:09 AM
sarmyth
sarmyth's Avatar
The link you provided is for cars with MacPherson strut setups, we have a double wishbone suspension up front; so those guys won't work. You'll likely need to replace the upper A arm with an aftermarket unit with a sliding balljoint.
But I personally wouldn't screw with it; just pump up your tire pressures a bit so when you corner you're not on the extreme outer edge of the tire. If you're lowered, that's another story.
If you do find something which can hold an alignment angle over time, let me know as I'd love some more negative to help even out my tire wear ( too much cornering =p ).
Old 09-28-15, 06:29 PM
sam430
sam430's Avatar
I guess the Tdemand is the best option out there.
Old 10-01-15, 06:07 PM
DoriSaru15
DoriSaru15's Avatar
Selling my TDemand upper arms soon. FYI
Old 10-02-15, 11:18 AM
sam430
sam430's Avatar
will this add camber? I thought you mentioned yours will get more negative.
Old 10-02-15, 12:10 PM
DoriSaru15
DoriSaru15's Avatar
Yes it adds both but my arms are design to go full demon camber
Old 03-06-16, 10:52 PM
sam430
sam430's Avatar
Default found something
fits our year.<br/>
ipwn
03-26-13 02:08 PM
mk4r34
Suspension and Brakes
02-20-12 12:24 PM
SPhoto
08-16-09 10:48 AM
gs300_r1
GS - 1st Gen (1993-1997)
08-05-05 11:35 AM
Quick Reply: Front Camber
