Suspension Springs, shocks, coilovers, sways, braces, etc.
GS300 BC Racing coilovers, rear clunking noises on a 3rd gen?
Old 07-14-15, 03:09 AM
fozzyf
fozzyf's Avatar
Default GS300 BC Racing coilovers, rear clunking noises on a 3rd gen?
I have recently bought a late 2005 GS300 SE-L, very pleased with it. It came already fitted with BC Racing coilovers (under a year old), however on one of the rear corners I am getting a clunking over light bumps. I've searched and searched and it seems a common fault on the mk2 GS's but I cannot seem to find anything on the mk3s?
I've checked all bolts and all are tight, all of the bushes seem ok so lost now? Can anyone help? I have the standard shock which I could try to fit just to confirm it is the shock itself or perhaps swap the 2 rear shocks over?
Thanks
Old 07-22-15, 04:36 AM
fozzyf
fozzyf's Avatar
Well I swapped the BC's for the standard shocks and all noises gone so it is definitely the coilovers causing this, however can anyone explain which part of the coilover itself makes the noise? Some suggested the cartridge? Is that the bottom part of the shock when the strut screws into it?
Old 11-02-15, 12:01 PM
ChiRaq
ChiRaq's Avatar
i have a 2006 Lexus GS430 and literally just got off the phone with BC racing and they stated that on the older BR series coilovers they dont have the rubber top mounts. Per the rep, the newer ones come with the rubber top mounts so that is probably the answer that you are looking for if you haven't found out already
Old 11-03-15, 06:23 AM
IXI187IXI
IXI187IXI's Avatar
its the strut mount. no rubber isolater between the mount and the spring
slickman82
ES - 6th Gen (2013-2018)
12-19-18 02:29 PM
brandon97
GS - 1st Gen (1993-1997)
04-07-11 07:03 PM
woodpecker
SC- 1st Gen (1992-2000)
04-04-10 12:34 AM
wj4
Suspension and Brakes
01-24-09 02:03 PM
Quick Reply: GS300 BC Racing coilovers, rear clunking noises on a 3rd gen?
