Suspension Springs, shocks, coilovers, sways, braces, etc.
Rear shocks are going bad soon
Old 04-14-15, 06:23 PM
CarKrayz
CarKrayz's Avatar
Default Rear shocks are going bad soon
I notice my driver rear is about an inch lower then my passenger rear.
I was told by my mechanic that the rear shocks are going bad soon.
Does anyone have any suggestions on what else are out there for OEM replacements besides KYB?
I want to keep my car stock and not trying to lower the car. Also not trying to spend way too much.
I am trying to restore the normal function how the car was originally.
I have the 07 gs350 AWD.
Any advice or suggestions would help. Thanks in advance
Old 04-14-15, 07:25 PM
chuckGS350
chuckGS350's Avatar
That' the way it is.
Mine 3/4 inch lower since 32K miles.
Car has 107K miles now.
Old 04-14-15, 08:09 PM
Gotcha350
Gotcha350's Avatar
Ummm....that shouldn't be the way it is...you have something wrong if one corner of your car is lower than the other one...
Old 04-16-15, 06:04 PM
monkeyRX
monkeyRX's Avatar
i don't believe shocks contribute to ride height - they are responsible for dampening. I would look into your springs.
Old 04-28-15, 08:39 AM
L's TLS
L's TLS's Avatar
I just noticed this morning the drivers side of my car is about a half inch lower than the passenger. After doing a search, everyone contributes it to the "Lexus Lean". Seems pretty common.
Old 05-10-15, 01:28 AM
ibidu1
ibidu1's Avatar
KYB's are the stock exact shocks! Even the old OEM say KYB on them. Ive replaced my rears and put them side by side no difference.
Old 05-11-15, 10:26 PM
sonnyhood
sonnyhood's Avatar
see my prev post, about shocks
but 2006-2008 had an old shock part number
2009-2011 3GS had an upgrade kyb part
the part number has a 1 on the end.
https://www.clublexus.com/forums/sus...-avs-450h.html
my rear right failed first, then front left after that, then i replaced all 4
I think the right rear shock takes the load from the chassis torque twist.
The flywheel spins clockwise as you sit in the car im guessing?
Replacing shocks made a huge difference to my car
roberta
GS - 1st Gen (1993-1997)
08-10-23 02:35 AM
Chlim1122
Suspension
09-25-17 06:37 AM
Andyb63
Suspension
10-13-15 05:24 AM
hieu
Suspension
11-16-14 09:32 PM
Lexmex
RX - 1st Gen (1999-2003)
10-08-07 06:25 PM
Quick Reply: Rear shocks are going bad soon
