Suspension Springs, shocks, coilovers, sways, braces, etc.
Caster arm Bushings
Old 09-26-14, 12:05 AM
angus
angus's Avatar
Default Caster arm Bushings
Has anyone replaced these in the 3GS?
Old 09-27-14, 03:22 AM
ibidu1
ibidu1's Avatar
Why do you want to adjust your caster? If it is off by a little its no big deal, as it does not wear your tires out.
Old 09-27-14, 08:54 AM
angus
angus's Avatar
This is not the point -
The factory caster arm bushings are what I suspect is the cause of our inside edge tire wear problem.
When the caster arm bushing is worn, it causes the wheels to toe out under braking which will cause the exact issue we have.
If someone has a camera they can mount to the fender, I bet we could see the wheel toeing out under braking.
Toe settings will cause much faster wear than camber will.
Old 10-03-14, 11:27 PM
angus
angus's Avatar
OK, So I got the bushings so we will see how it helps.
sdime94
04-04-16 11:54 AM
GS3KID
Suspension and Brakes
03-29-15 08:33 PM
kamikaze04
17
06-30-13 06:25 PM
BayAreaLex
06-12-13 09:30 AM
Quick Reply: Caster arm Bushings
