Suspension Springs, shocks, coilovers, sways, braces, etc.
Coilovers
Old 04-07-14, 04:07 PM
poorbong
poorbong's Avatar
Default Coilovers
Ive searched around the forum and seen a lot of people are using springs since they want to keep the stock suspension dampening. Are there any of u out there running on coilovers? If so, which ones and how the ride quality?
Old 04-07-14, 04:36 PM
IAMJAVEDG
IAMJAVEDG's Avatar
There are a few members using RS-R and BC Racing coilovers.
Both are great and priced well
Old 04-07-14, 04:56 PM
sam430
sam430's Avatar
Are there weight advantages with the coilovers? Seems the oem shocks looks lightweight (except the spring).
Old 04-07-14, 06:42 PM
GSTONY
GSTONY's Avatar
Rsr coils forget them AVS, perfect height and ride nice
gsintokyo (09-25-22)
Old 04-07-14, 08:14 PM
CaptAmazin
CaptAmazin's Avatar
So far I'm enjoying my RSR coilovers as well. 32 levels of dampening, so you can find what works best for you. I'm sitting at 15 and find it be close sport+ mode albeit slightly stiffer now.
Old 04-08-14, 09:52 AM
LGSFS2012
LGSFS2012's Avatar
I had BC's on 2013 and loved them, however on my 2014, i decided to run RSR Super Down and ran a fatter tire and what a dam difference. The BC's were nice but than you have to run a thin tire and it kills the ride.
Old 04-08-14, 10:26 AM
N54MPower
N54MPower's Avatar
When you say fatter, are you referring to the width of the tire or the sidewall? Do the coilovers require that you run a narrower tire because of space?
I'm curious, please explain.
Old 04-08-14, 02:38 PM
poorbong
poorbong's Avatar
Same here....why do u have to run smaller tires on BC?
Old 04-09-14, 10:12 PM
sam430
sam430's Avatar
I was thinking about bc w/swift ...what is the issue with bc?
Old 04-10-14, 11:03 AM
J5usa
J5usa's Avatar
Let me try to help answer your question. stock weight is heavier than average coilover setup. Weight does matter lighter is always better but has to be strong as well. Meaning the material used has to work both ways. for example we use 7075 aluminum instead of 6061. 7075 is what you call top tier aluminum.
We are currently finish up AVS compatible coilover setup for the GS Fsport model. these will be full 7075 aluminum. We have our current Lexus IS 3rd gen setup weighed at 17.5kg.
You can always ask the weight of the coilover and which material is used to the manufacture. They should be able to answer all your questions.
I hope this helps. good luck on your research
Old 04-10-14, 12:40 PM
Jaysoo
Jaysoo's Avatar
How much longer do you think the Avs compatible coilovers will be available? And a rough idea on the pricing? I'm thinking of pulling the trigger on RSRs
Old 04-10-14, 01:38 PM
J5usa
J5usa's Avatar
The GS RWD Fsport AVS is estimated to be done right after we finish up the IS AVS model. estimated time is safe to say within a month.
Old 04-11-14, 11:34 AM
sam430
sam430's Avatar
Keep us updated. Do you happen to know if the OEM adjustments are only +/- 1 clicks? I think it is.
Old 04-14-14, 12:41 PM
J5usa
J5usa's Avatar
I believe its 180 degree,equal to three clicks, but will have that confirmed
Old 06-03-14, 03:04 PM
sam430
sam430's Avatar
have you confirmed how much clicks will it translate to your coilovers?
BTW people, it's available. Thanks for making the kit.
group buy here
Quick Reply: Coilovers
