Suspension Springs, shocks, coilovers, sways, braces, etc.
Negative camber question
Old 02-26-14, 09:38 PM
3gsdippin
3gsdippin's Avatar
Default Negative camber question
What's up guys I got some wheels for my gs
They are 20x11 +10 with 245/35 for front and 255/35 rear the front seem to not rub but the rear fender sit on the tires The car is lowered on df210 I had the front fenders rolled and rears shaved my question is can I camber enough to clean the wheels thanks in advance
Old 04-27-14, 12:14 PM
Andrew@SonicMS
Former Sponsor
Andrew@SonicMS's Avatar
Running that aggressive of a fitment, I do not suggest you keep the lowering springs, as they're very soft. Consider upgrading to some sort of coilovers to get maximum adjustability.
You'll most likely need a front & rear camber kit to dial in the setup a lot better with your alignment shop. But yes, if you get a rear camber kit, you'll have a lot more room to tuck/clear the wheels.
Flash5
03-15-19 03:52 AM
gamma113
11-07-17 02:00 PM
Gplex1987
09-22-12 07:09 PM
richie3888
04-20-10 10:35 PM
1.5jzsupra
Suspension and Brakes
09-29-09 04:07 PM
Quick Reply: Negative camber question
