Suspension Springs, shocks, coilovers, sways, braces, etc.
rear tire wearing out after lowering?
Old 10-15-13, 04:37 PM
bossdom
bossdom's Avatar
Originally Posted by SNiiP3R
Sorry, I did not see your post. It seems that you have the correct specs for AWD, so you can ignore my previous post.
This is a really strange problem you're having. Normally lowering the car does not cause such excessive wear. With good alignment you should easily get 15,000 mi / 24,000 kl out of your tires. So, lowering is not an issue.
Question, have you checked the air pressure? An overinflated tire can sometimes wear out like that.
I was hoping to use the tires for at least 2-3 summers. since I only use the car for summer. I actually checked the tire pressure every week. didn't want to take the chance of wrecking the wheels. lexus and my mechanic don't have a clue since the wear is evenly. falkan told us the rubber type we bought was made of soft compound but supposed to still last for 24kl. i'm waiting for my contact with lexus if they have any recall about uneven power on a AWD. maybe next summer I will buy a more harder compound so it will last longer.
Old 10-15-13, 04:38 PM
bossdom
bossdom's Avatar
Originally Posted by 2013gs350
Mine are
http://www.tirerack.com/tires/tires....omCompare1=yes
rears start with 7/32 tread new the fronts start with 10/32 new
let me know how long those rubber last. i'm looking around for a better/ long lasting rubber.
Old 10-16-13, 09:47 AM
terrycs
terrycs's Avatar
Do you know how the wear rating compares between the front and rear tires?
Old 10-16-13, 12:11 PM
2013gs350
2013gs350's Avatar
ok oem factory tires are 235-40-19 od is 26.4
http://www.tirerack.com/tires/tires....utoModClar=AWD
i am using these
285-30-20 rear od is 26.8
245-35-20 front od is 26.8
i am getting about 8-10k miles out of a rear pair
Old 10-16-13, 01:15 PM
bossdom
bossdom's Avatar
front is 6/10 thread wear
rear is o/10 thread wear
Old 02-10-14, 07:48 PM
14GS350F
14GS350F's Avatar
What about the tread wear rating (ie 220......280....300 etc)
Old 03-18-14, 03:11 PM
Jaysoo
Jaysoo's Avatar
is anyone else having this problem? i just placed an order for a 2014 gs fsport and was looking around for lowering options.
Old 04-08-14, 04:38 PM
Kcook700
Kcook700's Avatar
Does your GS have the rear steering? Maybe that is whats making you go through tires...
Old 04-24-14, 06:20 AM
2013gs350
2013gs350's Avatar
3rd set of rear tires on the car getting 8-10 miles out of them
i am using these
the rears are 71509
http://www.michelinman.com/tire-sele...ails#techspecs
the fronts are 20206
Old 04-25-14, 06:23 AM
JayRo354
JayRo354's Avatar
A happy medium between alignment and set up is key. Uneven wear is a risk after lowering, so a proper set up will help your pockets from being emptied replacing tires.
Old 04-25-14, 02:07 PM
mdhaliwal
mdhaliwal's Avatar
Hey,
Just a thought but could it possible be due to the different spring rates? The Tanabe's are made for the RWD, and the AWD is about 200 lbs heavier (don't know how that is exactly split in terms of weight distribution). I will be putting RS*R Down springs on my car next month and will report back, apparently RS*R has springs specifically for the AWD spec.
Good luck!
Last edited by mdhaliwal; 04-25-14 at 02:10 PM. Reason: kg vs. lbs. - huge difference :D
Old 04-26-14, 06:00 AM
2013gs350
2013gs350's Avatar
i bought 3 different set of springs all 3 companies used a spring dyno to check all 3 they were all about the same in spring rate
Old 04-29-14, 07:49 AM
sungzilla
sungzilla's Avatar
try different tires
Old 04-29-14, 08:35 AM
bossdom
bossdom's Avatar
I talk to my lexus dealer and my car doesn't have the rear tires turning capabilities.
Old 04-29-14, 08:39 AM
bossdom
bossdom's Avatar
Originally Posted by mdhaliwal
Hey,
Good luck!
that could be the problem but I'm taking out my tanabe and replacing it with air bags. will let you guys know how this goes. i'll post pic when I get it installed.
Quick Reply: rear tire wearing out after lowering?
