Suspension Springs, shocks, coilovers, sways, braces, etc.
Coil overs causes check lights
Old 08-29-13, 03:13 PM
hakisaki
hakisaki's Avatar
Default Coil overs causes check lights
Installed my bc racing coils and a few lights came up, how do I get rid of them and what do we do with the plug that goes into factory struts?
Old 08-29-13, 03:41 PM
GS350Lexus
GS350Lexus's Avatar
Are you talking about avs suspension that your car is equipped with? If it is there is no way around it. Year and model would also help out.
Old 08-29-13, 03:57 PM
hakisaki
hakisaki's Avatar
2006 gs430 and I think it does have that where you can change it to sport mode?
Old 08-29-13, 04:58 PM
ibidu1
ibidu1's Avatar
Did you play with the setting on the sensor? I believe its on the drivers rear wheel, if I am not mistaken if you adjust it, it might be out of adjustment. Im sure someone will chime in about it.
Old 08-29-13, 05:33 PM
hakisaki
hakisaki's Avatar
idk if he did or not i'll look into it.
Old 08-29-13, 05:44 PM
ibidu1
ibidu1's Avatar
Check this thread
https://www.clublexus.com/forums/sus...be-nf210s.html
Old 08-29-13, 05:45 PM
vanlex
vanlex's Avatar
Old 08-29-13, 11:55 PM
designo
designo's Avatar
My car has AVS and I have installed BCR Coilovers, no lights no problem! AVS non operational that's all.
Old 08-30-13, 10:55 AM
hakisaki
hakisaki's Avatar
maybe it turned on from the battery still being connected during installation.
Old 08-30-13, 09:04 PM
XxGoKoUxX
XxGoKoUxX's Avatar
YUP! I have zero problems when I start the car, and the car's almost on the FLOOR. I've done zero adjustments to my sensors too! (if anyone here needed to do it anyways). And just like you, I can click on and off my sport mode, with no changes or CELs.
You weren't very specific as to what is popping up, there are tons of warning lights on our cars.
The car's battery can STILL be connected to the car while the installation of the BCR's are going on. I reinstalled my sensors after my shop thought the sensors were a part of the adjustable suspension system. Your shop may have just flipped the sensors backwards upon reinstallation, have you read through the threads the two above linked you to?
Old 08-31-13, 05:37 PM
hakisaki
hakisaki's Avatar
yea i read it all and when i get the car back tuesday from the dealer i'll let you know exactly what's on.
Old 08-31-13, 07:43 PM
XxGoKoUxX
XxGoKoUxX's Avatar
okie doke, hope everything works out okay in the end hakisaki
The biggest problem is when they accidentally reverse the arms when installing the suspension. It happens often, that's why we assume, so make sure to jack the car up and check it
Old 09-02-13, 02:43 PM
hakisaki
hakisaki's Avatar
how can you tell im getting the car back from the dealer tomorrow?
Old 09-02-13, 10:31 PM
XxGoKoUxX
XxGoKoUxX's Avatar
My bad, I assumed because I thought Saturday was Monday, LOL!
School's been kicking my butt and my sense of schedule is off lately.
Old 09-04-13, 02:22 PM
hakisaki
hakisaki's Avatar
Everything looks good and today I left the dealer and the vsc light came on
Quick Reply: Coil overs causes check lights
