Suspension Springs, shocks, coilovers, sways, braces, etc.
Camber Suggestion for GS350 AWD
Old 08-05-13, 07:41 PM
1SLOGS
1SLOGS's Avatar
Default Camber Suggestion for GS350 AWD
Hey CL Member I am looking for camber adjusters for the front of my car and i would greatly appreciate if someone could give me some suggestions on the different options i could have and that i could go with.
I have also attached a picture of what my camber is like right now i know it isnt much but is at -2.7 on both sides.
Thankyou in advanced,
1SloGS
Old 08-05-13, 07:49 PM
ibidu1
ibidu1's Avatar
Why is your toe so far out? Are these measurements after the alignment or before? How low are you?
Old 08-05-13, 07:52 PM
1SLOGS
1SLOGS's Avatar
The Toe measurement is before alignment i dont know how low i am but here are some pictures that could give you some idea.
Attached Thumbnails Camber Suggestion for GS350 AWD-980346_4911661680797_730094083_o.jpg   Camber Suggestion for GS350 AWD-919878_463985203685190_671967135_o.jpg
Old 08-05-13, 07:53 PM
Htle83
Htle83's Avatar
1SloGS
What are you lowered on?
Old 08-05-13, 07:55 PM
1SLOGS
1SLOGS's Avatar
BC Racing Coilovers BR type.
Old 08-06-13, 12:25 AM
ibidu1
ibidu1's Avatar
From the picture doesnt look like the chamber is too far off.
None the less you have SPC that make brackets for front and back.
Btw how bad are your vibrations being that low, have you installed the rings on the driveshafts to cure it?
Old 08-06-13, 09:30 AM
1SLOGS
1SLOGS's Avatar
I havent installed anything for the vibration which is there but idk how to go about getting rid of it and i didnt even know that there were rings that i needed to put on the driveshaft if so where can i get them and what are they called.
Thankyou.
Old 08-06-13, 10:27 AM
ibidu1
ibidu1's Avatar
Thankyou.
You have them made from a fabrication shop, supposedly it cures the vibrations
Old 08-06-13, 10:36 AM
ibidu1
ibidu1's Avatar
Here check this out
https://www.clublexus.com/forums/sus...rs-needed.html
Old 08-06-13, 04:40 PM
TexasTaco
TexasTaco's Avatar
Might want to read or try this too
https://www.clublexus.com/forums/ls4...y-3-years.html
Old 08-06-13, 08:20 PM
1SLOGS
1SLOGS's Avatar
Originally Posted by TexasTaco
Thank you i will take a look into them and see how to go about it.
wzwz8221
09-29-14 05:28 PM
pearllex09
04-05-14 01:57 AM
tekkie
12-28-12 04:29 AM
solo
08-22-06 08:51 AM
Quick Reply: Camber Suggestion for GS350 AWD
