Suspension Springs, shocks, coilovers, sways, braces, etc.
AWD Wobble/Vibration Solution - Testers Needed
Old 08-07-13, 01:45 AM
  #91
ibidu1
ibidu1's Avatar
Originally Posted by 1SLOGS
I wanna be a part of this cause i have a 2011 GS 350 AWD and am lowered on BC racing coils with Vossen wheels and am facing the issue with the vibrations and wobble on my car.
You need to look in the phone book for a metal fabrication shop. Give them the specs and they will make the spacers for you. A lot of shops have a minimum rate 50-75 bucks is what they would probably charge
Once you have them made pop off the front axles and install them, can all be done in one day.
But I read you have to make sure the spacers are properly centered and maybe even glued. to the axle.
Old 08-07-13, 03:46 AM
  #92
IXI187IXI
IXI187IXI's Avatar
not glued but they do need to be temporarily held centered on the axle prior to reinstalling the axle through the hub. once the axle is reinstalled, the pressure keeps it centered.
Old 09-19-13, 04:31 PM
  #93
msequence
msequence's Avatar
Tried this... no solution whats so ever. Still wobble present.
Old 09-19-13, 05:19 PM
  #94
ibidu1
ibidu1's Avatar
How low are you?
Old 09-20-13, 03:23 AM
  #95
IXI187IXI
IXI187IXI's Avatar
hmmm it took care of my wobble and i was tucking tires all around
Old 09-23-13, 05:30 AM
  #96
msequence
msequence's Avatar
Perhaps I may have another issue, however I was lowered about 2 inches and it still wobbled. I had these machined as well. Than I got air hahahah :P
Old 09-23-13, 07:11 AM
  #97
adrianwong
adrianwong's Avatar
Finally found a permanent solution. Traded car into BMW dealership.
Old 09-23-13, 01:58 PM
  #98
3gs350awd
3gs350awd's Avatar
Will it cause damage if I just leave it. And let it wobble like that.
Old 09-23-13, 07:07 PM
  #99
msequence
msequence's Avatar
Im pretty good now on bags. I just air up to stock height .. wobble poof!
Old 09-23-13, 09:31 PM
  #100
3gs350awd
3gs350awd's Avatar
i thought about air for a long time now.
afraid of reliability. and cost alot.
Old 09-24-13, 03:11 AM
  #101
IXI187IXI
IXI187IXI's Avatar
air has seemed to be the way to go for most as all the people ive heard about on air had no issues.
reliability imo is not an issue. i was on bags before (not in my lexus, different car) and i used to daily drive it for years about 80 miles round trip with no problems. just have to make sure you do the proper maintenance on the system every once and a while
Old 09-24-13, 02:20 PM
  #102
adrianwong
adrianwong's Avatar
I drove it for years like that with no issues, but it did bother me ALOT.....tried absolutely everything including changing out axles, balancing driveshaft, axles spacers, multiple alignments, hubs and even transmission and engine mounts.
When i finally decided to trade in the vehicle and returned in stock.......the ride was heavenly....it had been so long that i forgot what the Lexus was supposed to feel like......
Old 09-25-13, 08:53 AM
  #103
XxGoKoUxX
XxGoKoUxX's Avatar
must have been an extreme drop you did Adrian.
Old 09-25-13, 06:58 PM
  #104
3gs350awd
3gs350awd's Avatar
I've changed back to stock suspension twice now. I totally know what you mean.
Glad u mentioned all that. Pretty much answered all my curious questions I had. I'm just gonna ride low till I trade it in.
Old 09-25-13, 07:02 PM
  #105
3gs350awd
3gs350awd's Avatar
No wheel gap is more than enough wobble and vibration. I saw his car featured on vossen. I would say we have the same ride height.
Quick Reply: AWD Wobble/Vibration Solution - Testers Needed
