Specs needed for proper alignment. Purchased L-tuned Struts & Eibach Springs
Old 10-11-03, 01:18 PM
koreanpers
koreanpers's Avatar
Question Specs needed for proper alignment. Purchased L-tuned Struts & Eibach Springs
I purchased the above mentioned parts. However, no alignment shop said they can do it since the installed parts will lower the ride by about 1" to 1.25". They said they need the specs in order to align the car properly. Has anyone else had this problem?
Does anyone know the specs so that i can tell the alignment shop? Thanks
Old 10-11-03, 02:39 PM
Letsride
Letsride's Avatar
Arrow
WHAT?? They need to use the same specs as factory and try to get it as close to that as possible!! If they dont want to do that find somewhere else!!
Old 10-12-03, 09:59 AM
koreanpers
koreanpers's Avatar
O man..i am so confused. I called 5 alignment shops in town and they all said the same thing. They dont know how to do it. I said its only lowering the ride by 1"...but they said it would have to go back to the dealership for alignment..and im not gonna do that. the dealer here in town will never get a penny from me. They were very rude to me from the beginning.
Old 10-18-03, 03:18 PM
shftup
shftup's Avatar
Dont tell them about the drop. Just make an appointment, and let them do their work.
Its not that hard.......usually takes more time, but they should be able to get factory specs in line.
Good luck.
Old 10-19-03, 12:01 PM
DoubleWhoosh
DoubleWhoosh's Avatar
They should be able to align it to either stock or for a good street performance setup.
We do >2" drops all the time and can usually get things close enough to not cause excessive tire wear problems. Anything past 1.5" is becoming borderline though.
We have some pretty decent specs that we set stuff to for good street performance and also good tire wear characteristics.
Old 10-19-03, 02:21 PM
Letsride
Letsride's Avatar
Arrow
Todd what specs do you use?
Santanas
RC - 1st Gen (2015-present)
06-16-15 03:54 PM
dandd2
06-19-09 05:48 PM
al503
05-15-06 03:25 PM
EastCoastES
12-03-02 04:24 PM
gwu128
Suspension and Brakes
08-09-01 09:44 PM
Quick Reply: Specs needed for proper alignment. Purchased L-tuned Struts & Eibach Springs
