Slotted Drilled Rotors
Lexism,
Go to TireRack and look up the rotors for GS. This would give you your candidate list (mostly OEM size). Then, you could look up the reviews on them and see which one you like best. This would give you an idea of what to expect while other GS owners can describe their experiences.
Non-OEM size brakes you can look at are Brembos, Endless, AEM, Baer, StopTech, etc.
Do a search for something like "brake kit" or "brake upgrade".
Keep in mind that by going with drilled rotors, you are compromising some of the performance and life of the rotors (drilled rotors are morely prone to cracking, and from what I know, most shops do not resurface them (probably for that reason)). Also, drilled rotors have less surface area and don't stop as well as solid rotors (when overheating is not an issue).
Bottom line is: get all the info you can, so you make an informed decision and encounter no unpleasant surprises.
Good luck!
Good luck!
Steve G. can get you OEM sized Brembo Slotted & C/D Rotors.
And this whole talk of 'cracking' of drilled rotors? We're not tracking the cars with OEM brakes.
Plus, from pure functionality's sake, if we are not tracking the cars, we (technically) don't need c/d rotors, other than for looks.
The cross-drilled/slotted rotors are definitely more prone to warping...so don't expect long-life. They do, however, perform as good as OEM rotors with less fade. The effect of less surface area due to the cross-drilling is minimal, especially at higher speeds. The most effect on brake performance is rotor and caliper size and also the brake pad design. "Cracking" of the rotors is all hype...my understanding is that this was a problem with the early design rotors. Companies have since constructed theor rotors with beefier materials. Has anyone on CL suffered a cracked x-drilled rotor??
Stay away from the cross drilled/slotted rotors on ebay. I purchased them and received the wrong sizes for both of my cars. They were not shipped in Brembo boxes, there was just a Brembo stamp on the side of the rotor. I then called up Brembo and they told me they dont make cross drilled/slotted rotors. They are priced well but I dont think it's worth the aggravation.
Most C/D rotors are C/D by third party companies using standard blank OEM rotors from companies such as Brembo and Bradi. That's why there is Brembo stamped on the rotors.
