DIY rear sway bar install
Old 03-18-17, 12:05 PM
Bigairbare
Bigairbare's Avatar
Default DIY rear sway bar install
How to install rear sway bars Lexus is350
Old 03-18-17, 12:13 PM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Need more info. You should check out this thread:
https://www.clublexus.com/forums/sus...ar-thread.html
Lou
Old 03-23-17, 06:33 PM
Bigairbare
Bigairbare's Avatar
Thank You Sir
Old 03-25-17, 12:50 AM
DocIS250
DocIS250's Avatar
One major thing to remember about the installation is the orientation of the height sensor bolted to the lower control arm on the driver's side, if your IS has AFS. It's easy to miss. The following link will show you how it should be oriented.
https://www.clublexus.com/forums/sus...g-springs.html
Old 03-25-17, 07:11 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
This isn't applicable to the rear sway bar, only the front. It's also only an issue if doing the lower springs on 2009-2013 models while it can be a concern if doing the sway bar on 2006-2008 models (the height sensor bolts to different locations depending on the year of the car).
Jeff
Old 03-27-17, 01:46 PM
DocIS250
DocIS250's Avatar
Jeff
Jeff,
Thank you for the info. I suppose it was only an issue because I decided to replace the end links entirely. Upon initial install, I was unaware that disconnecting the lower portion of the end link would disconnect the height sensor arm from the lca.
dnasians
05-29-15 05:15 PM
Och
Suspension and Brakes
01-14-13 06:45 PM
GKLCPA
11-26-11 08:39 PM
ohiois350
08-09-09 08:05 PM
tomtnc
12-03-07 02:21 PM
Quick Reply: DIY rear sway bar install
