Clarification: OEM IS-F rear sway into IS250awd
Old 01-18-17, 12:11 AM
Nixcision
Nixcision's Avatar
Default Clarification: OEM IS-F rear sway into IS250awd
Just wanted to double-check:
Can the OEM IS-F Rear Sway bar be used on an IS250 AWD?
It looks like the Fsport one is interchangeable between both (correct?), so I would assume that you could swap these over too....
Thanks!
Old 01-18-17, 08:58 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Yes, it would fit.
You will of course need the correct bushings and if you have a 2009+ IS, you will also need the brackets and bolts as they are different.
Jeff
ap2s2k
05-31-17 06:43 PM
JdSwiper
IS F (2008-2014)
04-24-15 01:04 PM
JdSwiper
04-24-15 12:06 AM
MercuryISF
08-31-12 03:54 PM
Quick Reply: Clarification: OEM IS-F rear sway into IS250awd
