Question for RSR Spring Users
Old 12-15-16, 06:42 PM
blizz24
blizz24's Avatar
Default Question for RSR Spring Users
The RSR are very popular drop spring but I was wondering and for those who had the spring for a long time (years), have you had any issues with your stock suspension going out prematurely? Or any issues in the long run?
Old 12-16-16, 09:35 AM
Miintt
Miintt's Avatar
I'm curious about this also. I'd like to get springs too but don't want to risk damage to my shocks or other suspension components.
Old 12-16-16, 02:19 PM
blizz24
blizz24's Avatar
All the members with rsr are gone
Old 12-17-16, 05:51 AM
Napalvr
Napalvr's Avatar
I've had mine for a year and a half with no problems at all. Mine is AWD
madenz (03-04-17)
Old 12-18-16, 12:30 PM
mark3is
mark3is's Avatar
Had RSR downs on my 3is for two years now no problems at all
madenz (03-04-17)
Old 12-22-16, 06:09 AM
Phamkq
Phamkq's Avatar
Had my RSR downs professionally installed for almost 6 months now, no issues. Wished i went with superdowns to be honest (wheel gap still bugs me)
Old 12-22-16, 06:13 AM
Sheddy
Sheddy's Avatar
Had my RSR downs installed over a year and no issues.
Old 12-22-16, 10:13 AM
CLUM
CLUM's Avatar
No issues here with RSR Half-downs for 2 years
Old 12-24-16, 02:17 AM
Silveon
Silveon's Avatar
No issues on my end, it has been three months. I would consider swift springs or superdowns though; the drop is better in my opinion
Old 12-25-16, 10:10 PM
3actual
3actual's Avatar
The bigger the drop on stock struts the more likely you will prematurely wear/blowout the struts. A one inch drop is ideal for the stock struts and suspension geometry. However it sounds like a lot of people are having good results with rsr downs.
Old 12-28-16, 02:43 PM
Jmaarc13
Jmaarc13's Avatar
I heard the pressure put on the stock shocks would eventually cause the shocks to go out. I, instead went with the RSR Coilovers after removing the FSPort springs.
Old 12-31-16, 12:43 PM
Phamkq
Phamkq's Avatar
I went with springs for just that reason. Once my stock shocks go out, I'll just change the entire suspension and get coilovers
Old 12-31-16, 01:11 PM
Jmaarc13
Jmaarc13's Avatar
@Phamkq, Good move. I did the same to save me some ca$h....unfortunately I regret wasting the cost of the spring install. When you do finally go with Coilovers, you will be extremely excited about the smooth ride. My biggest concern now is, "am I going to run as I pull out or into this driveway"?
Old 01-07-17, 02:40 AM
Tyrant32
Tyrant32's Avatar
1) Do the RSR Downs void your factory warranty, and 2) do they disable the Sport + suspension adjustment on the F Sport model?
Old 01-07-17, 06:15 AM
Napalvr
Napalvr's Avatar
[QUOTE=Tyrant32;9728567]1) Do the RSR Downs void your factory warranty, and 2) do they disable the Sport + suspension adjustment on the F Sport model?[/QUOTE
Any aftermarket part can technically void your warranty if proved that that part did damage. The springs will not effect the adjustable suspension. I've had the downs on my AWD for nearly 2 years and it rides and handles like new
madenz (02-15-17)
Quick Reply: Question for RSR Spring Users
