No rubber with these?
Old 12-02-16, 09:50 AM
Equalizir
Equalizir's Avatar
Default No rubber with these?
Hi guys,
So I ordered these tops for my front springs. I recently acquired some used Espelir springs with new struts. I noticed the rubber on the top hats was crumbling so I ordered these tops assuming they came with the rubber. They did not so I'm wondering if their is a way to order new ones? I can't find a part number. Do I even need them? The third pic you can see where my thumb is has no rubber going around it for the strut to sit on.
Attached Thumbnails No rubber with these?-img_20161202_093420.jpg   No rubber with these?-img_20161202_093426.jpg   No rubber with these?-img_20161202_093432.jpg
Old 12-02-16, 11:37 PM
freakness
freakness's Avatar
Originally Posted by Equalizir
Hi guys,
Dude,
I believe the rubber you're referring to is the top of the flexible OEM boot/bellows/insulator protecting the strut as shown in number 9 on the diagram. Over time the flexible accordion bellows portion of the boot breaks away from the top portion and can make it appear as though they are two separate parts, which they are not.
http://www.lexuspartsnow.com/parts/l...157-24010.html
- Chester
Old 12-03-16, 12:23 PM
DA51
DA51's Avatar
There is hard rubber surrounding the part with the hole. Always replace the strut mount with new shocks. When the rubber fails inside the mount, you cannot torque the shock top nut, it will spin. And eventually you will get a thumping noise in the trunk. I used Monroe, too.
Old 12-03-16, 12:26 PM
DA51
DA51's Avatar
If your new springs came with hats on top, NO do not use the stock strut mount setup. Keep them just in case you want to go back to stock components.
Old 12-04-16, 03:46 PM
Equalizir
Equalizir's Avatar
Ok thanks guys!
silverlake
05-30-19 04:43 PM
Tommytbone
ES - 5th Gen (2007-2012)
07-20-16 12:06 PM
Alphaman19
Suspension and Brakes
04-24-15 09:04 PM
the90zkid
24
12-08-10 12:28 AM
FusionMan79
18
08-15-01 04:43 PM
Quick Reply: No rubber with these?
