Changing ride height
Passenger side
Driver side
need to raise my driver side a little I have a set of 19s and rub when turning. I have tein flexz's loosened the bottom nut and unable to rotate the coil do I need to loosen the preload to do this? Teins courtesy of Track5tar. Thanks for any help
Driver side
The preload should never be touched. Just loosen the lower locking nut and spin the shock body. It'll be hard to do if the coilover is really dirty, so spray some type of penetrating oil (pb blaster). If it is still too tough, then disconnect the lower shock mount from the LCA and spin it.
