92 SC400 front springs
For starters, sorry if there is already a thread about this, or this is the wrong place to post. I'm fairly new to the forum and I'm on mobile.
I recently bought a 92 SC400 that has had the front springs cut by the original owner. They're way too close to rubbing for my liking, it's gave the wheels some ugly negative camber, and the car sways while going highway speeds ( although I think that's just the bearings ). I'd like to go back to factory ride height, but I'm having some problems finding OEM ( or close to it ) front springs. Google has just lead me to lowering springs and expensive coilovers, and that's not what I want. I know that some Supra parts are interchangeable, but I wouldn't even know where to start looking. Any bros help me out?
Front springs
I am having a similar problem finding front springs for my 92 sc400 as well.
Left and right shocks, top hats, bump stops, etc are the same.
Only the springs are different.
I have ordered most everything from Mylparts, a vendor here.
The right front spring was discontinued, so I have ordered another same as left.
If this works, I will give you part numbers, prices, etc.
Discount code cl5 gets you another 10% discount from the guys above.
Hope this helps,
Alan
Hope this helps,
Alan
I installed the shock/spring assy on my 1992.
I used the same spring on the right as left.
Worked fine, same height both sides.
part number 48131-24410. price 91.76 each after cl5 discount.
Hope this helps
Alan
Hope this helps
Alan
danielbaz
Suspension and Brakes
04-17-08 07:32 PM
