Bump steer 92 400
Old 03-01-16, 06:01 AM
sc4hunnit
sc4hunnit's Avatar
check play by lifting the car and moving the wheel. usually you can see what IS MOVING.
Old 03-02-16, 06:22 AM
99rx
99rx's Avatar
Originally Posted by Sactolex
How do you determine if its just your bushings, or also your ball joint?
Dont want to spend $600 if i can get away with $75.
Symptoms:
Wandering@low speed over bumps.
Clunking driver front over bumps.
When in reverse, slowly reversing, tap on brakes makes a squish sound front driver, and seems front wheel kind of "shifts" then stops later than rest of wheels.
Its a visible shift
I've got the same reversing issue, but not the other two. Curious to see what conclusion you come to. Mine only has 87k miles on it too.
skytechja
GS - 1st Gen (1993-1997)
25
06-13-16 02:09 PM
xspsi6
Performance & Maintenance
15
11-04-12 05:22 PM
Billy305
Suspension and Brakes
07-19-09 08:47 AM
Chenzo26
02-08-08 06:15 PM
LS400_96
03-21-04 05:40 PM
Quick Reply: Bump steer 92 400
