Front end Maintainence
Old 01-13-16, 02:51 AM
S160dre
S160dre's Avatar
Thumbs down Front end Maintainence
Does anyone know any great or reputable suspension kits to replace front end parts such as upper lower control arms , tie rod ends (inner and outer) sway bar end links etc, if you do let me know. Having a sixteen year old GS dancing all over the road at high speeds is no fun.
Old 01-13-16, 02:56 AM
S160dre
S160dre's Avatar
Cool Interior parts
I'm hearing a little sound coming front the A/c vents even when the a/c isn't on , it was freaky at first , but it sounds like something rattling in there , is this common in GS's? What is it ?
Old 01-13-16, 01:02 PM
kamlung
kamlung's Avatar
its the servo motor unit... there is a write up here... it sounds like a hampster/gerbal scratching from inside the dash...
Old 01-13-16, 03:04 PM
mate01
mate01's Avatar
I hear that same sound in mine. Does that mean it's failing?
Old 01-13-16, 05:52 PM
firelizard
firelizard's Avatar
You could just get OEM replacement stuff from an auto parts retailer. Alternately, you could get all your arms and links from FIGS and/or Serial Nine.
Old 01-14-16, 09:48 AM
kamlung
kamlung's Avatar
yes it means it is on its way out... the worm gear inside is binding... so if you can take them apart now and regrease and realign the gears, you won't have to replace the whole motor... if you leave it for a while and it starts to grind really badly or just stops working altogether, it will be a more expensive fix replacing the whole motors...
the sound should go away as you toggle through the Modes if it is your mode servo (which it was on mine)
Old 01-14-16, 09:37 PM
ntwrkguy1
ntwrkguy1's Avatar
kamlung, do you know if the heater blend door actuator makes that same type of noise?
j2b4o
18
07-12-12 06:27 PM
handoverfi
05-10-12 07:22 AM
jolsamuel
Suspension and Brakes
11-05-11 11:07 PM
D-Boi
08-23-10 03:56 AM
horent135
12-17-08 09:28 PM
Quick Reply: Front end Maintainence
