06-08 Solution to brake dust issues?
Old 12-22-15, 03:35 PM
LeXUsFeEVa
LeXUsFeEVa's Avatar
Default 06-08 Solution to brake dust issues?
I know the 06-08 IS models are notorious for the brake dust issues mainly in the front. It's gotten so bad on my daily driver that the dust has actually burned/stained my stock chrome wheels.
SOLUTION: replace OEM chrome wheels with after market black faced work meisters!
ISSUE: I still find my self wiping the lips almost every day. I've tried low brake dust pads but it doesn't seem to help. Any suggestions?
Old 12-22-15, 04:49 PM
Ktran1039
Ktran1039's Avatar
Ceramic brake pads from amazon
Old 12-23-15, 07:41 AM
flektone
flektone's Avatar
There is a TSB with updated part numbers for OEM pads. Search around for it. I brought it back to the dealer and had the work done. Took care of the issue.
Old 12-23-15, 01:16 PM
mike33
mike33's Avatar
This is from Jeff lange regarding the different oem brake pads:
04465-30410 is the original performance pad part number. It is still available (factory used on 06-08 USA models and 06-12 Canada models)
04465-30400 is the low-dust optional pad part number. (factory used on 09-12 USA models)
04465-30450 is the TSIB brake pads meant to address the front brake squeal on IS/GS models. They are to be used in conjunction with new shims and rotors (04945-30330, 43512-30350 and 43516-30040)
04465-30400 are the pads that would have come on your car, and they are the low dust pads. 04465-30450 would appear to me to also be low dust pads, since the TSIB lists them as replacing 04465-30400, however I have not used them, I do not know what their pad compound is. The high dust pads are Textar T4146, the low dust pads are NBK D6893H.
Read more: https://www.clublexus.com/forums/sus...#ixzz3vBGTc66u
Old 12-23-15, 01:38 PM
IS-SV
IS-SV's Avatar
The Lexus low dust pads per TSB work and cut dust drastically. I had my fronts on 07 IS350 replaced at 30K miles at no charge.
Old 12-26-15, 09:40 PM
Parsa
Parsa's Avatar
ceramic pads
SolidG1
GS F (2016-present)
03-16-19 07:10 AM
Countdamon
10-05-16 09:07 AM
Vroomin350
Suspension and Brakes
03-27-12 05:51 AM
noenoe_pro
01-16-08 04:33 PM
engin_ear
Wheels, Tires & Brakes Forum
12
09-02-03 08:30 AM
Quick Reply: 06-08 Solution to brake dust issues?
