Lexus is350 2nd gen front brake rotors
Old 11-24-15, 01:22 AM
roccolexus
roccolexus's Avatar
Default Lexus is350 2nd gen front brake rotors
Hi guys,
I need help on my car's front rotors...firstly i need the specs for the OEM rotors and then the specs on aftermarket rotors that might last longer? My car's rotors lasts about 30000km...
Any ideas?
Old 11-24-15, 06:53 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
If you want the rotors to last longer, you should run a pad that won't wear them as quickly. Changing to a different rotor will likely not change how long they last by any considerable margin.
Which specs are you looking for? Disc thickness?
Jeff
Old 11-24-15, 09:11 PM
roccolexus
roccolexus's Avatar
Jeff
Hi,
Im looking for the thickness, diameter, bolts all the specs on the rotor so i can source elsewhere, agents are way to expensive
Old 11-26-15, 05:07 AM
See5
See5's Avatar
How did you know your rotors are worn if you don't have any clue about the thickness?
My rotors did over 80,000 km , I feel that I need to press the brake pedal farther to starts braking, but I don't really know if the rotors are worn.
I use Akebono brake pads they last 28000 km and show no brake dust which I believe is a worn iron from the rotor.
Old 11-26-15, 08:15 AM
roccolexus
roccolexus's Avatar
Hi,
The OEM lexus service centre told me they are worn, i want to know the specs so i can look elsewhere for aftermarket rotors
Old 11-26-15, 06:27 PM
mike33
mike33's Avatar
I replaced my front OEM rotors with Centric high carbon rotors, they are excellent. They can be purchased from amazon for about $75-80 each...
LF rotor part # 125.44138
RF rotor part# 125.44137
The link below has specs
http://ecx.images-amazon.com/images/...L._SL1500_.jpg
vscout
Suspension and Brakes
12
07-18-15 11:23 AM
biglexass
17
02-24-14 05:33 AM
inked13
11-19-13 04:03 PM
unit74
20
07-28-08 08:37 PM
NotFatBoy
11-18-06 03:04 PM
Quick Reply: Lexus is350 2nd gen front brake rotors
