New Control Arm
Old 11-04-15, 03:22 PM
RXGS
RXGS's Avatar
Default New Control Arm
So I bought a new control arm, and got one in the mail. Quick question though, the ball joint is extremely difficult to move, but I can wiggle the part in the bushings with my hand, is that normal? Or should that be solid? Sorry if that's a stupid question.
Old 11-04-15, 03:30 PM
SpectraBlu
SpectraBlu's Avatar
Are you talking about the bushing in the control arm that the camber adjustment bolt goes through?
Old 11-04-15, 03:34 PM
RXGS
RXGS's Avatar
The bushings on the ends where you bolt it to the car. It's the upper control arm
Old 11-04-15, 03:58 PM
SpectraBlu
SpectraBlu's Avatar
I don't think you should be able to move the sleeves in the bushings with your hand. Is this on your new arms?
Old 11-04-15, 04:02 PM
RXGS
RXGS's Avatar
Yes brand new, I'll return them.
Old 11-04-15, 04:07 PM
SpectraBlu
SpectraBlu's Avatar
Yeah that sounds sketchy. What brand are they?
Old 11-04-15, 04:14 PM
RXGS
RXGS's Avatar
Meyle. Didn't go with Dorman this time around because the last two times they sent control arms were the balljoints had zero resistance
Old 11-04-15, 04:18 PM
SpectraBlu
SpectraBlu's Avatar
You could try moog. I've never used their uca's, but their lower ball joints and tie rods are pretty good.
Old 11-04-15, 04:29 PM
RXGS
RXGS's Avatar
I'll probably end up going that route. This car has gone through a total of 6 upper control arms including the 2 original ones, 4 of which were on the right side. I'm selling the car so I didn't want to spend $250 again on Napa arms
Old 11-04-15, 04:30 PM
Gdwrench35
Gdwrench35's Avatar
DO NOT use dorman brand upper control arms. Absolute junk. Unless you enjoy changing them monthly, then by all means use them. I'd go with Moog as well. They make excellent stuff. All their parts are torture tested and have an excellent warranty.
To answer your questions, the ball joint being hard to move is normal, the sleeves in your bushings moving is normal. The part that is moving is an 'anti crush' sleeve. It should slide freely back and forth in the rubber bushing.
Old 11-04-15, 04:51 PM
RXGS
RXGS's Avatar
So a little play is normal?
Old 11-04-15, 07:52 PM
Gdwrench35
Gdwrench35's Avatar
If your referring to the sleeve in the middle of the bushing, yes.
A picture might help ......
Old 11-04-15, 10:24 PM
RXGS
RXGS's Avatar
Yeah the sleeve if I put my fingers on both ends I can move a tiny bit, but not much.
Old 11-05-15, 05:12 PM
Gdwrench35
Gdwrench35's Avatar
Yes, that's normal. That movement will go away once its torqued to the car. But I still strongly advise against using the Dorman brand.
Old 11-06-15, 02:29 PM
mkpoto
mkpoto's Avatar
How much was a replacement? I am waiting on replacement bushings.
Quick Reply: New Control Arm
