3IS 350 brake life?
3IS 350 brake life?
What life have you seen from your brakes? I'm at 19030 miles and they need to be replaced? This seems kinda ridiculous. I had an STi with big Brembo brakes that I got a lot more life out of. I can't do the crazy things in the IS that I could do in the STi. The IS is a lease so I am only going to put into it as little as I have to. I am contemplating taking it to a Toyota dealer to deal with.
Former Sponsor
If you're not experiencing any pulsating/vibration issues, just replace the pads and follow the break-in procedure. Sounds like the dealership is just milking you but you can get a second opinion through a mechanic.
Of course the Lexus dealer wants to milk me. This is a lease and I am not going to put any more money into the car than I have to. As long as the brakes are equivalent, I am ok with it.
Former Sponsor
There's no differentiation between a "Lexus" and "Toyota" rotor. Sounds like they're just blowing smoke. If the pads are worn, which is one cause for squealing, then just replace the brake pads. While you're there, you can check the thickness of the rotor and see if it has reached it's minimal thickness - which is stamped on the edge of the rotor. Save yourself the $200+ dollars and go to Toyota or do it yourself to save even more; like 4TehNguyen said, it's pretty easy.
Former Sponsor
$460 was quoted by Lexus for changing out rotors and pads. $209 is quoted by Toyota who will change out the pads and turn the rotors. Online, I am seeing about the $220 range for the parts alone without labor. Also keep in mind, this is just for the front axle.
In this situation, Toyota has the better deal. Should also ask them for a quote on changing out the rotors as well.
I found out that the price that I saw on the Toyota dealer's website ($209) was only for Toyota vehicles and not Lexus. I called to make an appointment and was quoted about $336 for pads and turning the rotors. Not sure what to do in this instance. I do not have the patience to work on a car. Last time I tried, I failed miserably.
I'm not happy that the brakes need replacing this soon and with this few miles. The Lexus dealer really didn't answer my question about why I was only hearing squealing from the right front wheel and not the other side. And the squealing was happening while the car was moving as opposed to coming to a stop. I think they just saw the pads being low and said I needed new brakes., I have never had a car that had brakes wear this fast.
Former Sponsor
Don't be discouraged from past experiences. Like others have said, it's an easy job, and you can find guides online. Without having to break the bank, you can ask around for a trusty mechanic and get it done through them. Build a relationship with them and they can easily help you with cost in the future; they'll probably teach you a thing or two as well.
My brakes began squealing months ago at 8000 miles. I don't drive the car much. Had it 15 months. Took it in and was told nothing wrong. Squeal due to slight rust possibly from not driving enough.Took it in again a month later, and again they say everything's okay. Took it in a 3rd time recently at 10,000 miles. Now he saying it's possibly from braking too much.
I've got 9 months left to this lease. I don't want to spend a lot of money on it. None of my other cars ever did this at 8000 miles. I've had G37, 335, VW GTI.
