98 GS300 Brake cylinder question. HELP!!!!!
Old 08-04-15, 05:49 PM
gsw300
gsw300's Avatar
Exclamation 98 GS300 Brake cylinder question. HELP!!!!!
Hi everyone,
I have a problem with my 98 gs300. Car is making a "motor boat" noise and my friend said it might be caused by the master brake cylinder. Note: car also makes a beeping noise while driving and my friend told me the master brake cylinder needs to be replaced. Can anyone shine some light on me as to if this is true or not? Thanks in advance.
Old 08-05-15, 09:13 AM
Alphaman19
Alphaman19's Avatar
It's true most likely but it's not the end of the world.
All '98 owners have probably replaced their BMC by now.
Get one from an 01+ GS.
Good luck
Old 08-05-15, 07:42 PM
rgarjr
rgarjr's Avatar
Yeah the master cylinder/brake booster on these cars is not your average vacuum base. It has a motor that goes bad and needs replacement.
Old 08-11-15, 10:49 PM
gsw300
gsw300's Avatar
Thumbs up
Thank you guys for the response.:thumbup:
Old 08-11-15, 10:54 PM
gsw300
gsw300's Avatar
Exclamation
Good luck
One more question, how much does the BMC usually go for new and/or used? and for labor, what would my grand total be?
Old 08-11-15, 10:56 PM
gsw300
gsw300's Avatar
Exclamation
Old 08-12-15, 06:57 AM
Alphaman19
Alphaman19's Avatar
New? As in from a dealer? Fa-Get-Aboudit (lol)
It'd probably be more than the current value of you car.
They run anywhere from $250-$600 used depending whether you buy it from a bone yard or ebay.
Just make sure it's from a +01 GS or SC
Labor at a Lexus dealer? Fa-Get-Aboudit (lol).
I'd say an average mechanic might charge you +-$400?
Honestly, it's not that difficult to install yourself; just bolt it in, bleed and done.
PS - If you drive it here to Jersey, I'd install it for $250
Good luck.
Old 08-12-15, 11:46 AM
rgarjr
rgarjr's Avatar
installing it is easy, just undo the 4 brake lines and remove 4 bolts. The more time consuming is bleeding the brakes.
The reason why it's very expensive is because the brake booster/master cylinder/ABS modulator is all integrated in just one part. Most cars have these 3 things separate.
Aerostar
Suspension and Brakes
14
01-30-17 09:27 PM
maser832
03-17-16 05:13 AM
ZeroState
04-17-11 05:06 PM
ray98LexGS
08-14-10 01:26 PM
gebo
Maintenance
04-02-05 02:15 PM
Quick Reply: 98 GS300 Brake cylinder question. HELP!!!!!
