Need Help!!! [brake pad and rotor advice]
Old 06-01-15, 10:15 PM
scott1256c
scott1256c's Avatar
You do apply anti-squel. As I recall, it comes with the pads. There are no shims. Apply anti-squel to the back of the pad and slip in.
Old 06-02-15, 12:12 PM
sthakor92
sthakor92's Avatar
Great! Thanks gonna order them now! My cars been squeaking the past ~1000 miles or so
Old 06-02-15, 12:27 PM
sthakor92
sthakor92's Avatar
Follow up question, running the OEM rear pads will be okay with these different front ones correct?
Old 06-02-15, 12:56 PM
scott1256c
scott1256c's Avatar
I see no problem with that. They are inexpensive enough that I'd change both front and rear now, if I were you. Unless you know you have a lot of life left in the rear. In either case, you should check the rear calipers to make sure the slider pin is still moving. If one brake pad is worn and the other is not, that is a sign the slider pin might be seized. Also if you can't spread the caliper for one of the sides, that is a sign that the pin might be seized..
Old 06-02-15, 07:42 PM
Slammer1
Slammer1's Avatar
Rear calipers are notorious for seizing on our cars (well documented). Make sure you have movement in the guide pins and even pad wear on both sides. Rear pads wear at less than half the rate of the front because your braking is likely 70/30 due to weight distribution so I wouldn't replace the rear pads unless necessary.
Old 06-04-15, 11:56 AM
sthakor92
sthakor92's Avatar
the fronts should be coming in on monday.. While i have the jack out I'll pop the rear wheels off and give the pads a check. Maybe I'll go ahead and grease the pins to be safe
Old 06-09-15, 07:36 PM
Slammer1
Slammer1's Avatar
[QUOTE=sthakor92;9064523]the fronts should be coming in on monday.. While i have the jack out I'll pop the rear wheels off and give the pads a check. Maybe I'll go ahead and grease the pins to be safe[/QUOTE
Good thinking. Extra grease on the slides is always a good idea.
Old 07-17-15, 05:31 PM
RXGS
RXGS's Avatar
Used Akebono ProAct pads all around and centric rotors front and back, and the car brakes great. Just make sure to paint the hats of the rotors so they don't rust.
Old 07-29-15, 07:07 PM
RRRacing
Sponsor
RRRacing's Avatar
Received 1,362 Likes on 621 Posts
Guys checkout our brake kits for the IS250/350:
http://www.rr-racing.com/category-s/132.htm
These are the best brake kits for the price featuring
* Wilwood lightweight calipers (look really nice in powder coated red),
* Black E-coating for long lasting corrosion protection
* Double Disc Ground for quieter and smoother stops
* Machined finish for a cleaner looking part
* Center Split core castings for proper heat transfer
* Cross drilled
We have State I and Stage II that feature a more massive Wilwood Arrow 6 calipers. Both can be used for street and the track.
In combination with our rear brake kit, you will get the best front-rear bias.
The same brake technology was utilized by several race car drivers -- you can read their testimony on our web site as well: http://www.rr-racing.com/category-s/193.htm
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
fxturbo
Suspension and Brakes
09-18-18 02:45 PM
Jtecnik
11-17-16 11:29 PM
e36m3s50
08-13-11 01:46 PM
masboy
GX - 1st Gen (2004-2009)
01-02-11 02:28 PM
lexneffect
04-18-07 04:36 PM
Quick Reply: Need Help!!! [brake pad and rotor advice]
