Need Help!!! [brake pad and rotor advice]
I see no problem with that. They are inexpensive enough that I'd change both front and rear now, if I were you. Unless you know you have a lot of life left in the rear. In either case, you should check the rear calipers to make sure the slider pin is still moving. If one brake pad is worn and the other is not, that is a sign the slider pin might be seized. Also if you can't spread the caliper for one of the sides, that is a sign that the pin might be seized..
Rear calipers are notorious for seizing on our cars (well documented). Make sure you have movement in the guide pins and even pad wear on both sides. Rear pads wear at less than half the rate of the front because your braking is likely 70/30 due to weight distribution so I wouldn't replace the rear pads unless necessary.
[QUOTE=sthakor92;9064523]the fronts should be coming in on monday.. While i have the jack out I'll pop the rear wheels off and give the pads a check. Maybe I'll go ahead and grease the pins to be safe[/QUOTE
Good thinking. Extra grease on the slides is always a good idea.
Sponsor
Guys checkout our brake kits for the IS250/350:
http://www.rr-racing.com/category-s/132.htm
These are the best brake kits for the price featuring
* Wilwood lightweight calipers (look really nice in powder coated red),
* Black E-coating for long lasting corrosion protection
* Double Disc Ground for quieter and smoother stops
* Machined finish for a cleaner looking part
* Center Split core castings for proper heat transfer
* Cross drilled
We have State I and Stage II that feature a more massive Wilwood Arrow 6 calipers. Both can be used for street and the track.
In combination with our rear brake kit, you will get the best front-rear bias.
The same brake technology was utilized by several race car drivers -- you can read their testimony on our web site as well: http://www.rr-racing.com/category-s/193.htm
* Cross drilled
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
e36m3s50
Suspension and Brakes
08-13-11 01:46 PM
lexneffect
04-18-07 04:36 PM
