Confused: Caster vs Control Arm. Same?
Old 04-28-15, 11:21 AM
Capitone
Capitone's Avatar
Default Confused: Caster vs Control Arm. Same?
150k miles so Im trying to replace the most problematic bushing(s), however in my research I'm getting the impression that Caster and Control are used interchangeably for our car. Is this right? I want to make sure before I make a purchase.
This is where I got the Caster Arm term:
https://www.clublexus.com/forums/sus...s-of-pics.html
However when I look it up, even the site the OP recommended initially (he changed to another brand 2nd run) is referring to the bushings as Control Arm. This is way too confusing. Can someone please shed a little bit of light here?
Thanks,
Capitone
Old 04-28-15, 01:13 PM
NorthStyle
NorthStyle's Avatar
The caster arm is also referred to as the #2 control arm for our vehicles. The part that he refers to in his post as the "#1 suspension arm" is the actual lower control arm (or #1 control arm, if you will).
Old 04-28-15, 01:49 PM
Capitone
Capitone's Avatar
Sheeeesh....That is as clear as mud. Thanks for shedding some real light on this Northstyle.
Capitone out
Old 04-28-15, 02:05 PM
Capitone
Capitone's Avatar
Spoke too soon....
Ok….thought I had it, but got dangit these vendors make it worst. Just for PHOTO’s sake, not purchase….which of these two are the true Caster Arm?
http://www.nextdayauto.com/2004-lexu...3-1739062.html
http://www.nextdayauto.com/2004-lexu...3-1739099.html
Same car, same year, same side, same description….different pics, different part numbers. Smh…or maybe Im missing something in my frustration.
Old 04-28-15, 02:31 PM
Capitone
Capitone's Avatar
Ah! I think I figured it out looking at the pics in the very 1st link (caster arm DIY).
Link 1 is for the # 1 Control Arm and Link 2 is definitely the caster/#2 Control arm.....The problem child I'm really looking for.
And then there was LIGHT!!!
Old 04-28-15, 10:03 PM
NorthStyle
NorthStyle's Avatar
Happy you were able to figure it out, and yes, you're correct with your identification of them.
dashan
06-27-18 06:48 PM
cbgdjg
01-26-17 04:33 PM
tedsterb
Suspension and Brakes
02-02-16 10:31 PM
aEO 37
05-02-10 05:48 AM
lexusMing
06-24-09 01:59 AM
Quick Reply: Confused: Caster vs Control Arm. Same?
