RS R super downs and toe adjustment...
Old 03-16-15, 10:22 AM
Letsstance
Letsstance's Avatar
Default RS R super downs and toe adjustment...
For people running rsr's super downs are you able to get your rear toe in spec? I know FIG Engineering now makes the rear camber kits but not sure if toe has been an issue. Thanks for any info.
Old 03-25-15, 08:56 AM
Matt3is
Matt3is's Avatar
Yes you are able to get your toe in spec. Everything was able to adjust except rear camber.
Old 03-26-15, 01:21 PM
criticalgt
criticalgt's Avatar
What did the read camber came out to be?
Old 03-26-15, 11:52 PM
ModInJapan
Lexus Enthusiasts
ModInJapan's Avatar
There should be no problem to get toe back to spec, ive done one in the past and the customer had no problems!
Old 03-27-15, 03:24 PM
mello03
mello03's Avatar
Toe will be fine. Just FYI my rear camber was -2.0 and -2.2 in the rear and I'm lowered 1inch. That's very similar to RSR down specs. The max spec on the rear is -2.3, so I'm sure that the super downs will push your rear out of spec. I did just install some SPC camber arms though and just had my car aligned. He set my rears at -1.4 on both sides. Easy install if you have your rear springs out. Toe will be fine but if you're worried about tire wear slap some camber arms on there.
Old 03-28-15, 12:37 AM
Letsstance
Letsstance's Avatar
Yea I def plan on getting a camber kit. I didn't know spc made a kit for the 3is yet. good to know
Bocatrip
02-17-22 02:02 AM
Steviebee
IS F (2008-2014)
02-26-19 02:29 PM
EffSport
Suspension and Brakes
23
02-13-15 08:41 PM
Sheehan1p
26
05-29-11 11:54 AM
menty
09-06-09 06:19 PM
Quick Reply: RS R super downs and toe adjustment...
