F-Sport Chassis Brace Review
Old 05-26-15, 06:05 AM
redspencer
OG Member
redspencer's Avatar
Originally Posted by knguyenk
It involves a few screws and bolts. I don't have PDF version of the instructions, but if I can scan my paper instructions if you need it.
Do you mind taking a look at your paper instructions to see what the X ft/lbs of torque is required for the bolts? I think it is 37 ft/lbs but I can't confirm.
I plan on removing my F-Sport chassis brace sometime soon in order to repaint some of the areas that have been scrapped over the years.
Old 05-26-15, 06:09 PM
knguyenk
knguyenk's Avatar
Originally Posted by A_Grasso
I don't have install instructions but all in all it took my guy about 10 minutes. He just removed several things from the rear and bolted the brace on in place of them. Hopefully someone can chime in and be of more help :/ Get back to us once you've had it installed!
I've attached my scan of the paper instructions for the rear chassis brace.
The 8 bolts are torqued to 19 N.m or 14 ft.lbf.
File Type: pdf
Old 05-26-15, 06:20 PM
redspencer
OG Member
redspencer's Avatar
Thanks!
Old 05-26-15, 06:44 PM
knguyenk
knguyenk's Avatar
Thanks!
You're welcome
Old 11-11-15, 02:04 PM
VTsuckah
VTsuckah's Avatar
Back from the dead.
I've been looking into the Chassis Brace and the Lexus dealers on ebay state that the brace will require the removal of the plastic panels under the car for 09-10 RWD model years. Does anyone know if this is true? Call me crazy, but everything underneath is the same for all 2IS model years.
Old 07-17-16, 04:06 PM
GSE21tuner
GSE21tuner's Avatar
Originally Posted by VTsuckah
Back from the dead.
I just installed one on mine and it was necessary to remove.
noycy003
CT 200h Model (2011-2017)
20
05-01-19 01:40 PM
steezy
Suspension and Brakes
16
04-23-13 08:50 PM
SJ408sgmIS
02-07-13 06:11 AM
Nezumi
07-05-10 10:10 AM
FoUr OuNcE
12-10-09 05:22 AM
Quick Reply: F-Sport Chassis Brace Review
