Everyone with Tanabe NF210 Springs - What Shocks Are You Running? Ride VS Stock?
Since the L-Tuned springs are discontinued, the NF210 are my top pick. I've found a used set for cheap, but curious what you all are running for shocks, and how you would say it has compared to the stock ride with that combination? If you would also mention whether you have sways, I'd be curious about that as well.
Thanks in advance!
Thanks in advance!
i was riding on NF210s on stock shocks. I like the ride a lot. the thing about these springs is that the front springs will get lower as they wear in while the rears stay the same. some RCAs would even out the drop. compared to stock Is a night and day difference. its still comfortable and not as aggressive as some higher rates but it takes away the stock floating feeling.
I used kyb gr2 with my nf210. It rides nice for a daily. I also have TRD bracing and sways. It's stiffer than stock but nowhere as harsh as coilovers that are dumped
I had these springs with stock shocks. Since the spring rate doesn't differ significantly from stock, the factory dampers should be fine assuming they are in good operating condition.
It rode great, but didn't lower enough for my liking.
The NF210 is the most modest drop spring available. Run the stock shocks all day with them and don't worry about a thing
Now a DF210, ya, I wouldn't run stock shocks since those springs offer too much of a drop for the stock shocks.
No, you're talking to someone who ran the combo for a long time and had no problems at all. Even after 100K miles when I removed the shocks they retracted smooth and showed no signs of any issues (rode great too).
gs3joe
05-09-10 06:15 AM
UberNoob
Suspension and Brakes
16
09-09-07 12:55 PM
