30mm rca and coilovers
sounds good. i think i'll go in that direction.
i was looking at pictures and i was wondering if anyones filled the gaps with urethane before? the rears definitely have gaps but the front i cant tell from the pics ive seen. (trying to plan this out without dropping that whole thing.
just weighing options
thanks for that info. i guess i'll find out about the rear diff noise soon. hope to get those things on come next week
i had that same type on my 240 for a while before i switched to solids. but theyre super easy. loosen the subframe and pop the tops on (theyre slotted). the bottoms you just remove a bolt and slip the collar on. easy easy
I would NOT want solid ones in my GS - the inserts are just right, offering a bit of stiffness but not too much.
