Front Suspension Front Tie Rod Questions
Old 12-14-14, 12:21 PM
benjiSC3
benjiSC3's Avatar
Default Front Suspension Front Tie Rod Questions
Been the proud owner of my 99 golden pearl white sc300 for about a year. With 175k miles the suspension is feeling a little "old" and worn and deciding to refresh some of it with
Supra Front LCA
Supra Front UCA
JDM bilstein Supra TT shocks and springs
Supra sway bar End Links
Supra TT Brakes
Whiteline/Prothane Steering Rack bushings
New Tires
Front Outer Tie Rods
Front Inner Tie Rod
Anyone know for sure if the
Outer Tie Rods
Inner Tie Rod
are interchangeable between the Supra and SC300?
Anyone on here have experience with the Battle Version
Outer and Inner tie rods vs OEM
Old 12-24-14, 09:14 AM
gtsfire
gtsfire's Avatar
Upper control arms are way more expensive than lower control arms for some reason. You can find aftermarket UCAs's though for significantly less. No reason to spend over $400 for one uca when you can get one for $100. I have Dorman UCAs on my 400 since last year and 30k miles ago. I've had no issues with them.
Old 12-24-14, 11:19 AM
eknine9
eknine9's Avatar
Just make sure they have a proper ball-joint.
https://www.clublexus.com/forums/sus...a-failure.html
Old 12-24-14, 09:32 PM
gtsfire
gtsfire's Avatar
No one should even look at those. I've got OEM Dormans. They look identical to the stock ones. Beck Arnely, AC/Delco make them also.
Attached Thumbnails Front Suspension Front Tie Rod Questions-image-2805863765.jpg
ScDoinIt
SC- 1st Gen (1992-2000)
15
09-10-11 04:55 PM
DJVe
Suspension and Brakes
07-31-11 11:45 AM
TheMole
04-01-08 06:06 PM
SC51
02-21-08 08:36 PM
Quick Reply: Front Suspension Front Tie Rod Questions
