Tanabe NF210
Tanabe NF210
Decided on this product as compared to the swift springs because it gave the best drop to spring rate near stock ratio, and this will have the most even drop based on specs and pix
Front 4.1kg/mm / 1.4 drop
Rear 8.2kg/mm / 1.0 drop
as compared to the other brands
RSR half downs
Front 4.60kg/mm / .8 drop
Rear 8.67kg/mm / .4 drop
RSR Downs
Front 5.48kg/mm / 1.4 drop
Rear 8.98kg/mm / 1.2 drop
S.Tech
Front 5.9kg/mm / 1.4 drop
Rear 8.4kg/mm / 1.0 drop
H. Tech
Front 5.7kg/mm / 1.0 drop
Rear 8.0kg/mm / .6 drop
Swift
Front 5.2kg/mm / 1.1 drop
Rear 7.2kg/mm / 1.1 drop
RSR half downs
RSR Downs
S.Tech
H. Tech
Swift
Looks good! It has that forward rake so the gap and the stance looks even all around Now i am excite for the speings to get here seeing the nice drops on the tanabes
The rear is about a two finger gap and the front is about 1-3/4 gap which is what I wanted since I'm switching to 19" wheels soon. So with the 19's the rear finger gap should go down to about 1-1/2 finger gap and the front should be just over a 1 finger gap
thanks man! yeah thats also what I want the slight nose down and the drop looks very nice its not like the usual IS350's that the front gap is bigger than the rear gap
