Post spring install issue
Old 11-18-14, 06:17 PM
JefferyISC
JefferyISC's Avatar
Default Post spring install issue
Hello All, after install of f-sport springs & sways I got a check headlight system message on dash. Does this have to do with self leveling headlamps? And require some recalibration, resetting, etc? If so, how is that accomplished short of the dealer? Thx much. Soooo..., do I need to adjust the brackets on my is350c the same manner that has been suggested elsewhere until the light goes off?
Old 11-30-14, 03:48 PM
MikeFoxx
MikeFoxx's Avatar
Yeah there are a few threads about this and I had the same problem. Just search and u'll see the thread that is a step by step on how to correct this. Literally takes a couple minutes to correct and once you find the sensor you'll understand why it happened. Driver side rear control arm is where it's located.
Old 12-08-14, 09:55 AM
JefferyISC
JefferyISC's Avatar
Thx Mike. That quick adjustment worked. I used pics from the other threads which helped.
LuisRo
Suspension and Brakes
05-09-17 03:51 PM
Vibes63
07-03-12 08:32 PM
justinp95
17
03-05-10 07:11 AM
jaredc
07-18-08 03:55 PM
Quick Reply: Post spring install issue
